跳转到主内容
Canon PowerShot G7X Lens Replacement
你所需要的
  1. Canon PowerShot G7X Lens Replacement, Dial: 步骤 1 中的图像 1,1
    • Remove the five 2mm Phillips #000 screws that are under the screen of the camera.
  2. Canon PowerShot G7X Lens Replacement: 步骤 2 中的图像 1,1
    • Remove the two 3mm Phillips #000 screws under the AV-out digital flap.
    • Remove the two 3 mm Phillips #000 screws from the side of the camera.
  3. Canon PowerShot G7X Lens Replacement: 步骤 3 中的图像 1,1
    • Remove the two 3 mm Phillips #000 screws on the side of camera with the flash toggle.
  4. Canon PowerShot G7X Lens Replacement: 步骤 4 中的图像 1,1
    • Remove the four 4 mm Phillips #000 screws from the plate on the bottom of the camera.
  5. Canon PowerShot G7X Lens Replacement: 步骤 5 中的图像 1,1
    • Remove the back plate.
  6. Canon PowerShot G7X Lens Replacement: 步骤 6 中的图像 1,1
    • Remove the three 3 mm Phillips #000 screws around the dial.
  7. Canon PowerShot G7X Lens Replacement: 步骤 7 中的图像 1,2 Canon PowerShot G7X Lens Replacement: 步骤 7 中的图像 2,2
    • Using the nylon spudger, gently lift the ZIF tab.
    • Disconnect the ribbon cable that connects the dial to the motherboard.
    • Remove the dial from the device.
  8. Canon PowerShot G7X Lens Replacement, Flash: 步骤 8 中的图像 1,2 Canon PowerShot G7X Lens Replacement, Flash: 步骤 8 中的图像 2,2
    • Remove the three, blue 5 mm Phillips screws from the back plate.
    • Remove seven 2 mm Phillips #000 screws.
  9. Canon PowerShot G7X Lens Replacement: 步骤 9 中的图像 1,2 Canon PowerShot G7X Lens Replacement: 步骤 9 中的图像 2,2
    • While using the plastic opening tool, gently pry the top plate off the camera.
  10. Canon PowerShot G7X Lens Replacement: 步骤 10 中的图像 1,2 Canon PowerShot G7X Lens Replacement: 步骤 10 中的图像 2,2
    • Using the black nylon spudger, gently lift the ribbon cable connected to the LCD screen housing until it comes out then remove the housing.
  11. Canon PowerShot G7X Lens Replacement: 步骤 11 中的图像 1,2 Canon PowerShot G7X Lens Replacement: 步骤 11 中的图像 2,2
    • Remove the 2 mm Phillips #000 screw underneath the top plate.
    • Remove silver plate.
  12. Canon PowerShot G7X Lens Replacement: 步骤 12 中的图像 1,1
    • Take the Phillips #000 and remove the three 5 mm screws from the front plate.
  13. Canon PowerShot G7X Lens Replacement: 步骤 13 中的图像 1,2 Canon PowerShot G7X Lens Replacement: 步骤 13 中的图像 2,2
    • Using the spudger, gently lift the ribbon cable from underneath the front plate.
    • Remove the front plate.
  14. Canon PowerShot G7X Lens Replacement: 步骤 14 中的图像 1,2 Canon PowerShot G7X Lens Replacement: 步骤 14 中的图像 2,2
    • Remove flash toggle plate.
    • Remove the 2mm Phillips #000 screws under the flash toggle.
  15. Canon PowerShot G7X Lens Replacement: 步骤 15 中的图像 1,2 Canon PowerShot G7X Lens Replacement: 步骤 15 中的图像 2,2
    • Flash contains charged capacitor. Shock hazard.
    • Using the black nylon spudger, gently lift the ribbon cable that connects the flash to motherboard and remove the flash from the device.
  16. Canon PowerShot G7X Lens Replacement, Lens: 步骤 16 中的图像 1,1
    • Remove the 5 mm Phillips #000 screw from the copper plate.
  17. Canon PowerShot G7X Lens Replacement: 步骤 17 中的图像 1,1
    • Using the black nylon spudger, lift the ribbon cable gently until it comes out.
  18. Canon PowerShot G7X Lens Replacement: 步骤 18 中的图像 1,1
    • Remove the copper plate to reveal connections to the lens.
  19. Canon PowerShot G7X Lens Replacement: 步骤 19 中的图像 1,1
    • Using the black nylon spudger, lift gently on the pin connector until it comes off.
  20. Canon PowerShot G7X Lens Replacement: 步骤 20 中的图像 1,2 Canon PowerShot G7X Lens Replacement: 步骤 20 中的图像 2,2
    • Using the spudger, gently lift on the ribbon cable until it comes out.
    • Separate the lens from the motherboard.
结论
另外一个人完成了本指南。
3条评论
Not that great of step by step. Lots of missed steps and lots different screw length and thread. Over all it's just an ok guide.
Nick Thomas - 回复
how do you tell if the lens is CCD or not
kingwayne77none - 回复
Poor instructions indeed. At step 11 silver plate still stuck. More screws than indicated.
Hugo Lyppens - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 70
总计 6,807
