跳转到主内容
Canon PowerShot G7X Dial Replacement
你所需要的
  1. Canon PowerShot G7X Dial Replacement, Dial: 步骤 1 中的图像 1,1
    • Remove the five 2mm Phillips #000 screws that are under the screen of the camera.
  2. Canon PowerShot G7X Dial Replacement: 步骤 2 中的图像 1,1
    • Remove the two 3mm Phillips #000 screws under the AV-out digital flap.
    • Remove the two 3 mm Phillips #000 screws from the side of the camera.
  3. Canon PowerShot G7X Dial Replacement: 步骤 3 中的图像 1,1
    • Remove the two 3 mm Phillips #000 screws on the side of camera with the flash toggle.
  4. Canon PowerShot G7X Dial Replacement: 步骤 4 中的图像 1,1
    • Remove the four 4 mm Phillips #000 screws from the plate on the bottom of the camera.
  5. Canon PowerShot G7X Dial Replacement: 步骤 5 中的图像 1,1
    • Remove the back plate.
  6. Canon PowerShot G7X Dial Replacement: 步骤 6 中的图像 1,1
    • Remove the three 3 mm Phillips #000 screws around the dial.
  7. Canon PowerShot G7X Dial Replacement: 步骤 7 中的图像 1,2 Canon PowerShot G7X Dial Replacement: 步骤 7 中的图像 2,2
    • Using the nylon spudger, gently lift the ZIF tab.
    • Disconnect the ribbon cable that connects the dial to the motherboard.
    • Remove the dial from the device.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 532
