跳转到主内容
Canon PowerShot G3 Zoom Control Spring Replacement
你所需要的
  1. Canon PowerShot G3 Zoom Control Spring Replacement, Zoom Control Spring: 步骤 1 中的图像 1,1
    • Start by removing all of the screws around the camera: from the front, back, sides, and bottom.
  2. Canon PowerShot G3 Zoom Control Spring Replacement: 步骤 2 中的图像 1,1
    • Once the screws are removed, remove the back panel. The panel should be able to be removed by hand.
  3. Canon PowerShot G3 Zoom Control Spring Replacement: 步骤 3 中的图像 1,1
    • Next remove the front and right side panels (the left side is attached to the front panel).
  4. Canon PowerShot G3 Zoom Control Spring Replacement: 步骤 4 中的图像 1,1
    • Finally, remove the top panel as shown.
  5. Canon PowerShot G3 Zoom Control Spring Replacement: 步骤 5 中的图像 1,3 Canon PowerShot G3 Zoom Control Spring Replacement: 步骤 5 中的图像 2,3 Canon PowerShot G3 Zoom Control Spring Replacement: 步骤 5 中的图像 3,3
    • With the top panel removed, locate the metal plate covering the zoom control on the underside of the panel (located on the forward left side, if the panel is oriented similarly to the first image.) This plate will also be connected to some circuit ribbon. Leave the ribbon attached to the plate.
    • Remove the screws from the plate, and lift and fold the plate along the attached circuit ribbon to the right (as shown in third image.)
  6. Canon PowerShot G3 Zoom Control Spring Replacement: 步骤 6 中的图像 1,2 Canon PowerShot G3 Zoom Control Spring Replacement: 步骤 6 中的图像 2,2
    • With the top panel and metal plate removed, locate the zoom control on the underside of the panel (located on the forward left side if the panel is oriented similarly to the first image.) It will be located directly under the metal plate and circuit ribbon that was removed in the previous step.
    • Once the zoom control is located, remove the faulty zoom control spring from the metal pegs on the panel and zoom control.
  7. Canon PowerShot G3 Zoom Control Spring Replacement: 步骤 7 中的图像 1,2 Canon PowerShot G3 Zoom Control Spring Replacement: 步骤 7 中的图像 2,2
    • Replace the zoom control spring with a comparable spring, attaching the loop ends to the same metal pegs to which the previous spring was attached (on the panel and zoom control.)
结论
Cory Jeanes
于11/07/15注册
101 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 835
