跳转到主内容
Canon PowerShot G3 Speaker Replacement
你所需要的
  1. Canon PowerShot G3 Speaker Replacement, Speaker: 步骤 1 中的图像 1,1
    • Start to remove the screws around the camera: from the front, back, sides, and bottom.
  2. Canon PowerShot G3 Speaker Replacement: 步骤 2 中的图像 1,1
    • Once the screws are removed, remove the back panel. The panel should be able to be removed by hand.
  3. Canon PowerShot G3 Speaker Replacement: 步骤 3 中的图像 1,1
    • Next remove the front and right side panels (the left is attached to the front panel).
  4. Canon PowerShot G3 Speaker Replacement: 步骤 4 中的图像 1,1
    • Finally, remove the top panel as shown.
  5. Canon PowerShot G3 Speaker Replacement: 步骤 5 中的图像 1,2 Canon PowerShot G3 Speaker Replacement: 步骤 5 中的图像 2,2
    • The front of the camera should now resemble the picture shown. (Image 1)
    • Remove the capacitor/speaker housing using your finger nail or other thin object to lift it up around the edges. (Image 2)
  6. Canon PowerShot G3 Speaker Replacement: 步骤 6 中的图像 1,1
    • To remove the circuit ribbon (brown strip) pull it out of the plastic piece it is connected to.
  7. Canon PowerShot G3 Speaker Replacement: 步骤 7 中的图像 1,1
    • You should now be able to see how the capacitor/speaker housing slides out of the frame.
  8. Canon PowerShot G3 Speaker Replacement: 步骤 8 中的图像 1,2 Canon PowerShot G3 Speaker Replacement: 步骤 8 中的图像 2,2
    • Disconnect the speaker wires from the camera, then use a small flat head screw driver to lift the speaker out of its housing.
    • Order a new speaker from the manufacturer or take it to a local electronics store to see if they have one.
结论
Ryan Riales
于10/22/15注册
201 声望
创作了2篇指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 14
总计 317
