当前版本的文档还未经巡查,您可以查看最新的已查核版本。
The screen is fragile, handle with care.
Push the screen down and away from the camera.
Remove the single Phillips #0 screw at the base of the rotating arm. This will allow you to remove the screen cover.
Remove the black bar attached to the data ribbon cable. You will use this with the replacement.
The screen will be loose in the front.
Slide the black bar from underneath the white socket.
The data ribbon will remain attached to the defective screen. Both of these can be discarded.
The ribbon and black bar are fragile. You will want to be very delicate with it. It will be difficult to insert.
Insert the ribbon into the white socket.
You will have to hold this ribbon in place while placing the black bar back into the socket. You may need assistance with this part of the step.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
