In this guide we will be replacing the screen of a Canon PowerShot G3.
The screen is fragile, handle with care.
Push the screen down and away from the camera.
Remove the single screw at the base of the rotating arm. This will allow you to remove the screen cover.
Remove the black bar attached to the data ribbon cable. You will use this with the replacement.
The screen will be loose in the front.
Slide the black bar from underneath the white socket.
The data ribbon will remain attached to the defective screen. Both of these can be discarded.
Warning: The ribbon and black bar are fragile. You will want to be very delicate with it. It will be difficult to insert.
Insert the ribbon into the white socket. You will have to hold this ribbon in place while placing the black bar back into the socket. You may need assistance with this part of the step.
Turn screen up, and toward the camera. Remain perpendicular to camera.
Replace monitor cover using single screw, making sure cover is on the outside. (Screw from step 6)
Turn screen parallel to the camera. Refasten metal bracket with the screws from step 5.
These screws are small, and you may need assistance in screwing them back in.
Replace back panel. Make sure the metal part of the panel goes under the metal part of the rotating arm or the screw won't go in.
Put the four screws back in from step 2 and 3 respectively.
Step 2 screws go in the outside of the panel. Step 3 screws go in on the underside of the panel.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
