跳转到主内容
Canon PowerShot G16 Lens Replacement
你所需要的
  1. Canon PowerShot G16 Lens Replacement, Battery: 步骤 1 中的图像 1,3 Canon PowerShot G16 Lens Replacement, Battery: 步骤 1 中的图像 2,3 Canon PowerShot G16 Lens Replacement, Battery: 步骤 1 中的图像 3,3
    • Open the battery flap on the bottom of the camera by applying pressure and pushing in the direction of the arrow.
    • Remove your finger and allow the flap to pop open.
  2. Canon PowerShot G16 Lens Replacement: 步骤 2 中的图像 1,3 Canon PowerShot G16 Lens Replacement: 步骤 2 中的图像 2,3 Canon PowerShot G16 Lens Replacement: 步骤 2 中的图像 3,3
    • Push the brown lever so that it pivots counterclockwise.
    • Grip and remove the battery.
  3. Canon PowerShot G16 Lens Replacement, Button Circuit Board: 步骤 3 中的图像 1,3 Canon PowerShot G16 Lens Replacement, Button Circuit Board: 步骤 3 中的图像 2,3 Canon PowerShot G16 Lens Replacement, Button Circuit Board: 步骤 3 中的图像 3,3
    • Remove the ring around the lens by simultaneously pressing the black button located at the bottom right of the ring and rotating the ring counterclockwise.
  4. Canon PowerShot G16 Lens Replacement: 步骤 4 中的图像 1,1
    • Remove the four 3.3 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
  5. Canon PowerShot G16 Lens Replacement: 步骤 5 中的图像 1,1
    • Remove the 3.3 mm screw on the right side of the viewfinder using a Phillips #00 screwdriver.
  6. Canon PowerShot G16 Lens Replacement: 步骤 6 中的图像 1,1
    • Remove the two 3.3 mm screws near the speaker using a Phillips #00 screwdriver.
  7. Canon PowerShot G16 Lens Replacement: 步骤 7 中的图像 1,1
    • Open the port cover by lifting up the tab with your finger and remove the 3.3 mm screw underneath the cover using a Phillips #00 screwdriver.
    • Remove the other 3.3 mm screw below the ports using a Phillips #00 screwdriver.
  8. Canon PowerShot G16 Lens Replacement: 步骤 8 中的图像 1,2 Canon PowerShot G16 Lens Replacement: 步骤 8 中的图像 2,2
    • Using your fingers, carefully pull the the back cover off by grabbing the bottom left of the back cover and pulling outwards.
  9. Canon PowerShot G16 Lens Replacement: 步骤 9 中的图像 1,1
    • Using your fingers, carefully pry the front cover off starting at the bottom right.
  10. Canon PowerShot G16 Lens Replacement: 步骤 10 中的图像 1,2 Canon PowerShot G16 Lens Replacement: 步骤 10 中的图像 2,2
    • Remove the 3.8 mm screw at the bottom right of the port cover housing using a Phillips #00 screwdriver.
    • Lift away the port cover housing.
  11. Canon PowerShot G16 Lens Replacement: 步骤 11 中的图像 1,1
    • Reorient the camera so that you are looking at the back.
    • Make sure to pull the connector straight down as pulling up may cause harm to the connector.
    • Unplug the button circuit board from the motherboard by unlocking the ZIF connector (gently lift the brown lock that keeps the cable in place).
    • Pull the connector downwards with the tweezers.
  12. Canon PowerShot G16 Lens Replacement: 步骤 12 中的图像 1,1
    • Remove the 3.0 mm screw on the top of the button memory board using a Phillips #00 screwdriver.
    • Remove the 2.8 mm screw on the bottom of the button memory board using a Phillips #00 screwdriver.
  13. Canon PowerShot G16 Lens Replacement: 步骤 13 中的图像 1,1
    • Lift the button circuit board away from the camera.
  14. Canon PowerShot G16 Lens Replacement, LCD: 步骤 14 中的图像 1,3 Canon PowerShot G16 Lens Replacement, LCD: 步骤 14 中的图像 2,3 Canon PowerShot G16 Lens Replacement, LCD: 步骤 14 中的图像 3,3
    • Do not pull the connector upwards as doing so may harm the connector housing.
    • Unlock the ZIF connector for the large connector ribbon by lifting up on the brown flap with the plastic opening tool.
    • Gently pull the connector straight out of the housing with your fingers.
  15. Canon PowerShot G16 Lens Replacement: 步骤 15 中的图像 1,2 Canon PowerShot G16 Lens Replacement: 步骤 15 中的图像 2,2
    • Unplug the small connector ribbon by pulling the cable outwards from the camera using a spudger or your fingers.
  16. Canon PowerShot G16 Lens Replacement: 步骤 16 中的图像 1,1
    • Be careful of the copper plate that may fall out once you lift the LCD screen away.
    • Gently lift the LCD away from the camera housing.
  17. Canon PowerShot G16 Lens Replacement, Motherboard: 步骤 17 中的图像 1,2 Canon PowerShot G16 Lens Replacement, Motherboard: 步骤 17 中的图像 2,2
    • Be careful not to bend the EMI shield.
    • Lift and remove the copper EMI shield.
  18. Canon PowerShot G16 Lens Replacement: 步骤 18 中的图像 1,1
    • Reorient the camera so that you are looking at the front.
    • Remove the 2.8 mm screw right above the screw holding the lens on using a Phillips #00 screwdriver.
    • Remove the 3.3 mm black screw to the left of the front viewfinder using a Phillips #000 screwdriver.
  19. Canon PowerShot G16 Lens Replacement: 步骤 19 中的图像 1,1
    • Remove the 6.8 mm screw to the left of the rear viewfinder using a Phillips #00 screwdriver.
    • Remove the 5.2 mm screw to the right of the rear viewfinder using a Phillips #00 screwdriver.
  20. Canon PowerShot G16 Lens Replacement: 步骤 20 中的图像 1,2 Canon PowerShot G16 Lens Replacement: 步骤 20 中的图像 2,2
    • Remove the top 2.3 mm screw from the side with the ports using a Phillips #00 screwdriver.
    • Remove the 4 mm screw right below the one you just removed using a Phillips #00 screwdriver.
  21. Canon PowerShot G16 Lens Replacement: 步骤 21 中的图像 1,2 Canon PowerShot G16 Lens Replacement: 步骤 21 中的图像 2,2
    • Reorient the camera so that you are looking at the back of the camera.
    • Remove the rear viewfinder casing by firmly gripping it and pulling it out bottom first.
    • When reassembling, make sure that the viewfinder is fitted correctly beneath the top cover.
  22. Canon PowerShot G16 Lens Replacement: 步骤 22 中的图像 1,1
    • Remove the newly uncovered 2.8 mm screw from the right of the viewfinder using a Phillips #00 screwdriver.
    • Remove the 4.9 mm screw from top right of the metal casing on the back using a Phillips #00 screwdriver.
    • Remove the 4.3 mm screw from bottom right of the metal casing on the back using a Phillips #00 screwdriver.
    • Remove the newly uncovered screws from the right of the viewfinder using a Phillips #00 screwdriver. (Note, they're already removed on the picture)
  23. Canon PowerShot G16 Lens Replacement: 步骤 23 中的图像 1,1
    • Remove the 2.7 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
  24. Canon PowerShot G16 Lens Replacement: 步骤 24 中的图像 1,1
    • Reorient the camera so that you are looking at the side with the black felt circle.
    • Use caution around this black felt covered circle that is right below the screw to be removed. This is the speaker and can easily be damaged if pressed too hard or poked with a screwdriver.
    • Remove the 2.8 mm screw from the right side of the camera if you are looking at the front lens using a Phillips #00 screwdriver.
  25. Canon PowerShot G16 Lens Replacement: 步骤 25 中的图像 1,1
    • Remove the metal casing from the back by lifting it away from the camera.
  26. Canon PowerShot G16 Lens Replacement: 步骤 26 中的图像 1,1
    • Disconnect the cable on the top of the motherboard by lifting it up vertically using a plastic opening tool.
  27. Canon PowerShot G16 Lens Replacement: 步骤 27 中的图像 1,2 Canon PowerShot G16 Lens Replacement: 步骤 27 中的图像 2,2
    • Disconnect the cable on the back of the camera to the left of the viewfinder by lifting it up vertically using a plastic opening tool.
  28. Canon PowerShot G16 Lens Replacement: 步骤 28 中的图像 1,2 Canon PowerShot G16 Lens Replacement: 步骤 28 中的图像 2,2
    • Remove the top portion of the casing by firmly grasping it and pulling it upward to lift it off.
    • Some force may be required, but be careful to not bend either side of the top casing up too much or you will damage it.
  29. Canon PowerShot G16 Lens Replacement: 步骤 29 中的图像 1,3 Canon PowerShot G16 Lens Replacement: 步骤 29 中的图像 2,3 Canon PowerShot G16 Lens Replacement: 步骤 29 中的图像 3,3
    • Open the two ZIF connectors by flipping them up using a plastic opening tool on the motherboard.
    • Make sure to pull the cable ribbon straight out and not up because pulling it up may harm the connector.
    • Be careful not to pinch the cable while pulling it out because it can easily be damaged if pinched. It is helpful to pull it out by the tabs that are built into the connector ribbon.
    • Disconnect the two cable ribbons by pulling them straight out.
  30. Canon PowerShot G16 Lens Replacement: 步骤 30 中的图像 1,2 Canon PowerShot G16 Lens Replacement: 步骤 30 中的图像 2,2
    • Disconnect the lens cable from the motherboard by lifting it up vertically from the motherboard using a plastic opening tool.
  31. Canon PowerShot G16 Lens Replacement: 步骤 31 中的图像 1,2 Canon PowerShot G16 Lens Replacement: 步骤 31 中的图像 2,2
    • Be careful not to pinch the cable while pulling it out because it can easily be damaged. It is helpful to pull it out by the tabs that are built into the connector ribbon.
    • Remove the small cable towards the top by pulling it straight out of its connector using tweezers or your fingers.
    • Remove both Screws on the bottom side of the motherboard
  32. Canon PowerShot G16 Lens Replacement: 步骤 32 中的图像 1,1
    • Lift the motherboard out of the camera.
  33. Canon PowerShot G16 Lens Replacement, Lens: 步骤 33 中的图像 1,1
    • Reorient the camera so that black lens cover is facing you with viewfinder on top.
    • Remove the four 5.3 mm screws around the lens using a Phillips #00 screwdriver.
    • Remove the 3.8 mm screw above the lens using a Phillips #00 screwdriver.
  34. Canon PowerShot G16 Lens Replacement: 步骤 34 中的图像 1,1
    • Remove the black plastic cover surrounding the lens by gripping and lifting upwards.
  35. Canon PowerShot G16 Lens Replacement: 步骤 35 中的图像 1,1
    • Remove the black 3.8 mm screw on the far left side using a Phillips #000 screwdriver.
  36. Canon PowerShot G16 Lens Replacement: 步骤 36 中的图像 1,2 Canon PowerShot G16 Lens Replacement: 步骤 36 中的图像 2,2
    • Grip the left and right halves of the camera and wiggle them apart.
  37. Canon PowerShot G16 Lens Replacement: 步骤 37 中的图像 1,1
    • Use caution around the black felt covered circle. This is the speaker and can easily be damaged.
    • Pick up the half of the camera that contains the lens.
    • Remove top 4 mm screw from the strap holder using a Phillips #00 screwdriver.
    • Remove the middle 3.8 mm screw next to the left speaker using a Phillips #00 screwdriver.
  38. Canon PowerShot G16 Lens Replacement: 步骤 38 中的图像 1,1
    • Remove the cable strap bracket by lifting it away.
  39. Canon PowerShot G16 Lens Replacement: 步骤 39 中的图像 1,1
    • Do not pull the connector upwards because doing so may harm the connector housing.
    • Be carful not to pinch the cable while pulling it out.
    • Disconnect the cable in the top left by pulling it straight out of its connector.
  40. Canon PowerShot G16 Lens Replacement: 步骤 40 中的图像 1,2 Canon PowerShot G16 Lens Replacement: 步骤 40 中的图像 2,2
    • Lift the metal frame away from the lens.
    • After you remove the metal frame, the lens will be by itself.
结论
To reassemble your Canon PowerShot G16, follow these instructions in reverse order.
12等其他人完成本指南。
Tyler Koski
于01/11/16注册
303 声望
撰写一个指南
团队
Cal Poly, Team 70-6, Forte Winter 2016 Cal Poly, Team 70-6, Forte Winter 2016 的会员
CPSU-FORTE-W16S70G6
4 名成员
创作了7篇指南
7条评论
A well understood and skillfully documented and photographed guide. Not for the faint hearted, but that's not the author's fault!
cambrs00 - 回复
I would like to thank you for the guide. I used this guide yesterday to change the lenses of a G15. It has some differences, but your guide helped me a lot. I'm not a technician and I almost gave up on the way, but in the end everything worked out. Thanks!
Daniel Simões - 回复
You haven’t disassembled the lens yet or exposed the sensor which may have dust on it and be in need of cleaning or even replacement. How is that done, wise guy?
Benjamin Netanyahu - 回复
Anybody knows a good and reliable seller where i can buy the lens replacement part for the canon g16? Thanks!
Darío Fernández - 回复
To be clear, can this procedure be used to replace a lens that has got stuck due to a drop? And a source(s) for the replacement part would be great.
Greg Scott - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 17
过去 30 天: 46
总计 8,600
