跳转到主内容
Canon PowerShot G16 LCD Replacement
你所需要的
  1. Canon PowerShot G16 LCD Replacement, Battery: 步骤 1 中的图像 1,3 Canon PowerShot G16 LCD Replacement, Battery: 步骤 1 中的图像 2,3 Canon PowerShot G16 LCD Replacement, Battery: 步骤 1 中的图像 3,3
    • Open the battery flap on the bottom of the camera by applying pressure and pushing in the direction of the arrow.
    • Remove your finger and allow the flap to pop open.
  2. Canon PowerShot G16 LCD Replacement: 步骤 2 中的图像 1,3 Canon PowerShot G16 LCD Replacement: 步骤 2 中的图像 2,3 Canon PowerShot G16 LCD Replacement: 步骤 2 中的图像 3,3
    • Push the brown lever so that it pivots counterclockwise.
    • Grip and remove the battery.
  3. Canon PowerShot G16 LCD Replacement, Button Circuit Board: 步骤 3 中的图像 1,3 Canon PowerShot G16 LCD Replacement, Button Circuit Board: 步骤 3 中的图像 2,3 Canon PowerShot G16 LCD Replacement, Button Circuit Board: 步骤 3 中的图像 3,3
    • Remove the ring around the lens by simultaneously pressing the black button located at the bottom right of the ring and rotating the ring counterclockwise.
  4. Canon PowerShot G16 LCD Replacement: 步骤 4 中的图像 1,1
    • Remove the four 3.3 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
  5. Canon PowerShot G16 LCD Replacement: 步骤 5 中的图像 1,1
    • Remove the 3.3 mm screw on the right side of the viewfinder using a Phillips #00 screwdriver.
  6. Canon PowerShot G16 LCD Replacement: 步骤 6 中的图像 1,1
    • Remove the two 3.3 mm screws near the speaker using a Phillips #00 screwdriver.
  7. Canon PowerShot G16 LCD Replacement: 步骤 7 中的图像 1,1
    • Open the port cover by lifting up the tab with your finger and remove the 3.3 mm screw underneath the cover using a Phillips #00 screwdriver.
    • Remove the other 3.3 mm screw below the ports using a Phillips #00 screwdriver.
  8. Canon PowerShot G16 LCD Replacement: 步骤 8 中的图像 1,2 Canon PowerShot G16 LCD Replacement: 步骤 8 中的图像 2,2
    • Using your fingers, carefully pull the the back cover off by grabbing the bottom left of the back cover and pulling outwards.
  9. Canon PowerShot G16 LCD Replacement: 步骤 9 中的图像 1,1
    • Using your fingers, carefully pry the front cover off starting at the bottom right.
  10. Canon PowerShot G16 LCD Replacement: 步骤 10 中的图像 1,2 Canon PowerShot G16 LCD Replacement: 步骤 10 中的图像 2,2
    • Remove the 3.8 mm screw at the bottom right of the port cover housing using a Phillips #00 screwdriver.
    • Lift away the port cover housing.
  11. Canon PowerShot G16 LCD Replacement: 步骤 11 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Reorient the camera so that you are looking at the back.
    • Make sure to pull the connector straight down as pulling up may cause harm to the connector.
    • Unplug the button circuit board from the motherboard by unlocking the ZIF connector (gently lift the brown lock that keeps the cable in place).
    • Pull the connector downwards with the tweezers.
  12. Canon PowerShot G16 LCD Replacement: 步骤 12 中的图像 1,1
    • Remove the 3.0 mm screw on the top of the button memory board using a Phillips #00 screwdriver.
    • Remove the 2.8 mm screw on the bottom of the button memory board using a Phillips #00 screwdriver.
  13. Canon PowerShot G16 LCD Replacement: 步骤 13 中的图像 1,1
    • Lift the button circuit board away from the camera.
  14. Canon PowerShot G16 LCD Replacement, LCD: 步骤 14 中的图像 1,3 Canon PowerShot G16 LCD Replacement, LCD: 步骤 14 中的图像 2,3 Canon PowerShot G16 LCD Replacement, LCD: 步骤 14 中的图像 3,3
    • Do not pull the connector upwards as doing so may harm the connector housing.
    • Unlock the ZIF connector for the large connector ribbon by lifting up on the brown flap with the plastic opening tool.
    • Gently pull the connector straight out of the housing with your fingers.
  15. Canon PowerShot G16 LCD Replacement: 步骤 15 中的图像 1,2 Canon PowerShot G16 LCD Replacement: 步骤 15 中的图像 2,2
    • Unplug the small connector ribbon by pulling the cable outwards from the camera using a spudger or your fingers.
  16. Canon PowerShot G16 LCD Replacement: 步骤 16 中的图像 1,1
    • Be careful of the copper plate that may fall out once you lift the LCD screen away.
    • Gently lift the LCD away from the camera housing.
结论
7等其他人完成本指南。
Jonathan Harger
于01/11/16注册
1,207 声望
创作了5篇指南
团队
Cal Poly, Team 70-6, Forte Winter 2016 Cal Poly, Team 70-6, Forte Winter 2016 的会员
CPSU-FORTE-W16S70G6
4 名成员
创作了7篇指南
8条评论
1) Step 11 needs to be updated
2) Add Tweezers to the "tools needed" part at the beginning
Otherwise nice instruction
Martin Salamon - 回复
Nice set of instructions, although I had a real problem at step 11, and I recommend it be updated.
The instructions for step 14 should be copied-and-pasted into step 11.
Looking at the instructions for step 11, it was not at all clear that the brown lock-flap needed to be lifted first, and that the connector would then come out quite easily. Applying tweezers to the connector without first knowing about the brown lock-flap could easily lead to damaging the ribbon cable, as almost happened in my case.
So, for anyone reading this (in case the instruction set is not updated by the author), use the instructions for step 14 when you are at step 11. The connector will come out easily after the brown lock-flap is lifted, and the "connector" is NOT the grey plastic part that you see; it is in fact simply the end of the ribbon cable.
Thank You to the author. This instruction set saved me a bunch of money.
Christian Ristow - 回复
Also about step 11: Twezers may harm the cable. After opening the brown lock you can just carefully let the cable get out on step 13 while lifting the button circuit board away from the camera. On the reverse order,after replacement, twezers are needed to push the cable gently in.
Ανεφέλετη Προβιά - 回复
Great instructions and comments, a real help however any ideas where I can get a good quality LCD please?
Jon Mayers - 回复
Ebay has some cheap options.
emmbee - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 40
总计 4,287
