跳转到主内容
Canon PowerShot G12 Rear Function Setting Dial Replacement
你所需要的
  1. Canon PowerShot G12 Rear Function Setting Dial Replacement, Rear Function Setting Dial: 步骤 1 中的图像 1,1
    • Remove the three screws on the bottom of the camera using a Phillips-head 00 screwdriver.
  2. Canon PowerShot G12 Rear Function Setting Dial Replacement: 步骤 2 中的图像 1,1
    • Remove all of the screws on both the left and right side of the camera.
  3. Canon PowerShot G12 Rear Function Setting Dial Replacement: 步骤 3 中的图像 1,1
    • Looking at the front side of the camera, there is a port on left side of the camera labeled HDMI.
    • Remove the one screw on the side of the HDMI port.
  4. Canon PowerShot G12 Rear Function Setting Dial Replacement: 步骤 4 中的图像 1,1
    • Remove the screw on the right side of the view finder on the back side of the camera.
  5. Canon PowerShot G12 Rear Function Setting Dial Replacement: 步骤 5 中的图像 1,1
    • Using a spudger, carefully pry open the back side of the camera starting directly under the camera's serial label.
    • Make sure all sides of the back case are loose before trying to force it off of the camera. It should be removed with relatively little effort.
  6. Canon PowerShot G12 Rear Function Setting Dial Replacement: 步骤 6 中的图像 1,1
    • The back case is still attached to the camera with a yellow ribbon cable. The socket has a black flip-up lid that must be flipped up before the cable can be removed. Use precision tweezers to remove the cable.
  7. Canon PowerShot G12 Rear Function Setting Dial Replacement: 步骤 7 中的图像 1,1
    • Put the camera aside and look to the interior to the camera's back shell.
    • Peel off the thick, plastic seal over the metal plate near the yellow ribbon cable.
  8. Canon PowerShot G12 Rear Function Setting Dial Replacement: 步骤 8 中的图像 1,1
    • Remove the four screws from the metal plate using a Phillips-head 00 screwdriver.
  9. Canon PowerShot G12 Rear Function Setting Dial Replacement: 步骤 9 中的图像 1,1
    • Remove the spring from its socket using precision tweezers allowing the metal plate with the function dial to be removed.
  10. Canon PowerShot G12 Rear Function Setting Dial Replacement: 步骤 10 中的图像 1,1
    • Using precision tweezers, pry the old function dial out of its socket leaving only a black, metal ring attached.
  11. Canon PowerShot G12 Rear Function Setting Dial Replacement: 步骤 11 中的图像 1,1
    • Attach the new function dial simply by pressing it into the black, metal ring until you hear a click.
结论
3等其他人完成本指南。
团队
USF Tampa, Team 1-5, Leahy Winter 2015 USF Tampa, Team 1-5, Leahy Winter 2015 的会员
USFT-LEAHY-W15S1G5
3 名成员
创作了5篇指南
2条评论
Thank you so much!! I needed to replace the entire rear cover, because Canon doesn't sale just the wheel separately. your guide was the best one I found on the web. I think you ought to make a video of it, I admit I didn't see the "black flip-up" in part 6 so that part (putting the cable back in) was the most aggravating part for me.
But again thank you so much!
Maya Shemolewitz - 回复
Very good guide, the only one I’ve seen so far. Thanks for that>
Philip Knowles
Philip Knowles - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 40
总计 2,598
