跳转到主内容
Canon PowerShot G12 LCD Screen Replacement
你所需要的
  1. Canon PowerShot G12 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 1,1
    • Open the LCD screen from its locked position so the screen is visible.
  2. Canon PowerShot G12 LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Flip the LCD screen perpendicular to the camera exposing the side screws.
    • Using a Phillips-head 00 screwdriver, unscrew the screws on both sides of the LCD screen.
  3. Canon PowerShot G12 LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Remove the front plate which states the Canon brand by prying open the side farthest from the camera simply with your fingers.
    • The circuit and internal wires will be exposed.
  4. Canon PowerShot G12 LCD Screen Replacement: 步骤 4 中的图像 1,1
    • Flip the LCD screen vertically and remove the final screws on the outer edge of the screen with the same Phillips-head 00 screwdriver. All screws have Loctite (blue) on them so they a difficult to turn. Make sure your Phillips screw driver fits perfectly. Sometimes a new screwdriver will need to have the tip filed down a little to fit.
    • The internal mechanisms will become loose and be able to be taken out.
  5. Canon PowerShot G12 LCD Screen Replacement: 步骤 5 中的图像 1,1
    • Using a spudger, remove the external shell of the LCD screen leaving only the metal internal circuit board and screen attached.
  6. Canon PowerShot G12 LCD Screen Replacement: 步骤 6 中的图像 1,1
    • Using a pair of precision tweezers, carefully remove the yellow circuit connector from the port on the green circuit board.
    • Pull the yellow circuit connector down removing the screen from the metal shell.
  7. Canon PowerShot G12 LCD Screen Replacement: 步骤 7 中的图像 1,1
    • Place the new LCD screen into the metal shell with the yellow connector tab facing outward.
    • Connect the new screen with the green circuit board ensuring you use the tweezers to connect it fully into the port.
    Many steps were left out here in this tutorial, especially removing the broken LCD display from its metal case. Try YouTube German video at https://www.youtube.com/watch?v=ZNx2ylpj... from http://www.kamera-station.de. This video shows the complete disassembly and reassembly process, although it's in German. You can at least see the process by pausing and replaying the video. I could not find an English video. Richard Taylor, Elizabeth City, NC, 10/22/2016.
    Richard Taylor - 回复
结论
3等其他人完成本指南。
团队
USF Tampa, Team 1-5, Leahy Winter 2015 USF Tampa, Team 1-5, Leahy Winter 2015 的会员
USFT-LEAHY-W15S1G5
3 名成员
创作了6篇指南
2条评论
ATTENTION
Connector of cable between camera and lcd board can be fit up or down side
Mark it before disconnect
Dufour - 回复
Hello!
I wanted to change the screen but it seems that camera screen differ from each other according to the country where you bought it has anyone any piece of advice ?
I bought it in Singapore but live in Europe and I’m afraid to waist money buying a European one!
Chloe a - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 20
过去 30 天: 64
总计 7,636
