跳转到主内容
Canon PowerShot G11 Top Cover Replacement
你所需要的
  1. Canon PowerShot G11 Top Cover Replacement, Front Cover: 步骤 1 中的图像 1,2 Canon PowerShot G11 Top Cover Replacement, Front Cover: 步骤 1 中的图像 2,2
    • Push the button on the bottom right of the camera and then remove the plastic surrounding the lens.
  2. Canon PowerShot G11 Top Cover Replacement: 步骤 2 中的图像 1,1
    • Use the spudger to pop off front case.
  3. Canon PowerShot G11 Top Cover Replacement: 步骤 3 中的图像 1,1
    • Pull the loosened cover off and you are finished.
  4. Canon PowerShot G11 Top Cover Replacement, Top Cover: 步骤 4 中的图像 1,1
    • Once both the front and rear covers are removed, disconnect this ribbon cable by flipping it up and disconnecting it.
  5. Canon PowerShot G11 Top Cover Replacement: 步骤 5 中的图像 1,1
    • Remove these three screws from the rear side of the camera.
  6. Canon PowerShot G11 Top Cover Replacement: 步骤 6 中的图像 1,1
    • Remove this screw from the front of the camera.
  7. Canon PowerShot G11 Top Cover Replacement: 步骤 7 中的图像 1,1
    • Disconnect this cable from the motherboard by sliding it in the direction of the cable (toward the top of the camera).
  8. Canon PowerShot G11 Top Cover Replacement: 步骤 8 中的图像 1,1
    • Remove the top cover and you are finished.
结论
另外一个人完成了本指南。
Dustin Brinegar
于01/21/15注册
688 声望
创作了4篇指南
团队
USF Tampa, Team 5-6, Brown Winter 2015 USF Tampa, Team 5-6, Brown Winter 2015 的会员
USFT-BROWN-W15S5G6
3 名成员
创作了6篇指南
一条评论
In step 5, it is only necessary to take out the 2 SST screws at ~ 10 and 3 o’clock. The grey screw at 7 stays with the body.
In step 7, you need to SLIDE the connector toward the top of the camera toward the dial. The tweezers in the photo are moving LEFT, not toward the viewer as I interpreted it. If you lift it up as if to disconnect a socket (like in step 4) away from the mother board with tweezers, you’ll easily destroy the delicate connector (as I found out).
Dimwit - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 1,655
