跳转到主内容
Canon PowerShot G11 Rear Dial Replacement
你所需要的
  1. Canon PowerShot G11 Rear Dial Replacement, Rear Cover: 步骤 1 中的图像 1,1
    • Remove the three screws on the bottom of the camera using the 00 sized phillips head screw driver.
  2. Canon PowerShot G11 Rear Dial Replacement: 步骤 2 中的图像 1,1
    • Remove the four screws on the left side of the camera.
  3. Canon PowerShot G11 Rear Dial Replacement: 步骤 3 中的图像 1,1
    • Remove the screw on the right side of the camera.
  4. Canon PowerShot G11 Rear Dial Replacement: 步骤 4 中的图像 1,1
    • Open up the HDMI port on the right side of the camera. Then remove the screw in the HDMI port.
  5. Canon PowerShot G11 Rear Dial Replacement: 步骤 5 中的图像 1,1
    • Remove the screw to the right of the view finder on the rear of the camera.
  6. Canon PowerShot G11 Rear Dial Replacement: 步骤 6 中的图像 1,1
    • Use the spudger to crack open the case.
  7. Canon PowerShot G11 Rear Dial Replacement: 步骤 7 中的图像 1,1
    • The rear case is still attached to the camera with a ribbon cable. The socket has a flip up lid that must be flipped up before the cable can be removed. Use the tweezers to flip the cable attachment up.
  8. Canon PowerShot G11 Rear Dial Replacement: 步骤 8 中的图像 1,1
    • The rear cover is now unattached from the camera.
  9. Canon PowerShot G11 Rear Dial Replacement, Rear Dial: 步骤 9 中的图像 1,1
    • Remove the plastic covering of the left side of the rear case interior.
  10. Canon PowerShot G11 Rear Dial Replacement: 步骤 10 中的图像 1,1
    • Remove the four screws that are now accessible with the removal of the plastic covering them.
  11. Canon PowerShot G11 Rear Dial Replacement: 步骤 11 中的图像 1,2 Canon PowerShot G11 Rear Dial Replacement: 步骤 11 中的图像 2,2
    • After the screws are removed, pull the metal bracket out of the camera.
  12. Canon PowerShot G11 Rear Dial Replacement: 步骤 12 中的图像 1,1
    • Push the dial out from the other side of the cover.
  13. Canon PowerShot G11 Rear Dial Replacement: 步骤 13 中的图像 1,1
    • Remove the dial from the case completely.
结论
2等其他人完成本指南。
Dustin Brinegar
于01/21/15注册
688 声望
创作了4篇指南
团队
USF Tampa, Team 5-6, Brown Winter 2015 USF Tampa, Team 5-6, Brown Winter 2015 的会员
USFT-BROWN-W15S5G6
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 20
总计 2,124
