跳转到主内容
Canon PowerShot G1 X Screen Casing Replacement
你所需要的
  1. Canon PowerShot G1 X Screen Casing Replacement, Screen Casing: 步骤 1 中的图像 1,1
    • Remove the screws on the outside of the screen case shown in the photo.
  2. Canon PowerShot G1 X Screen Casing Replacement: 步骤 2 中的图像 1,2 Canon PowerShot G1 X Screen Casing Replacement: 步骤 2 中的图像 2,2
    • Remove the screws on the side of the screen casing next to the hinge on the camera.
  3. Canon PowerShot G1 X Screen Casing Replacement: 步骤 3 中的图像 1,1
    • Remove the back side of the screen casing. When removing this back casing there will be a clear plastic piece inside, remove this as well. If this is the piece you are servicing, replace it and skip to the conclusion of this guide.
  4. Canon PowerShot G1 X Screen Casing Replacement: 步骤 4 中的图像 1,2 Canon PowerShot G1 X Screen Casing Replacement: 步骤 4 中的图像 2,2
    • With the plastic piece removed, locate the screws on the outside and inside of the casing shown in the photos. Remove these screws.
  5. Canon PowerShot G1 X Screen Casing Replacement: 步骤 5 中的图像 1,1
    • Locate the four clips on the metal piece covering the back of the screen as seen in the photo. Push each of these clips in towards the center of the piece and pull up on the metal plate.
  6. Canon PowerShot G1 X Screen Casing Replacement: 步骤 6 中的图像 1,2 Canon PowerShot G1 X Screen Casing Replacement: 步骤 6 中的图像 2,2
    • Completely remove the casing from the screen and replace.
结论
Joseph Cosgrove
于02/12/17注册
313 声望
创作了3篇指南
团队
USF Tampa, Team 20-1, Remmell Spring 2017 USF Tampa, Team 20-1, Remmell Spring 2017 的会员
USFT-REMMELL-S17S20G1
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 24
总计 514
