跳转到主内容
Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement
你所需要的
  1. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement, Power/Shutter Button Panel: 步骤 1 中的图像 1,2 Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement, Power/Shutter Button Panel: 步骤 1 中的图像 2,2
    • On the top-center of your device, turn off the camera by pressing the power button.
    • Put your finger on the battery door and slide the battery door to the right to open it.
    • Push the release button downward and it will release the battery.
  2. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: 步骤 2 中的图像 1,1
    • Use the Phillips #00 screwdriver to remove the screws.
  3. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: 步骤 3 中的图像 1,1
    • Remove the two 4.0mm screws on the bottom of the camera located near the battery door using a Phillips #00 screwdriver.
  4. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: 步骤 4 中的图像 1,1
    • At the bottom of the camera next to the battery door, remove two more screws using the Phillips #00 screwdriver.
  5. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: 步骤 5 中的图像 1,1
    • To remove the back portion of the camera case, use your fingers to carefully pry the case apart at the seam.
  6. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: 步骤 6 中的图像 1,2 Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: 步骤 6 中的图像 2,2
    • On the motherboard there should be a white port. Using the spudger, disconnect it from the motherboard.
  7. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: 步骤 7 中的图像 1,1
    • Follow the green and white wire. There is a gray piece of rubber holding the button into place. Remove it with the spudger.
  8. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: 步骤 8 中的图像 1,1
    • Lift the panel off from the top of the camera with your hands.
结论
Michelle Ngo
于07/23/19注册
595 声望
创作了3篇指南
团队
UW Tacoma, Team S1-G3, Liner Summer 2019 UW Tacoma, Team S1-G3, Liner Summer 2019 的会员
UWT-LINER-SU19S1G3
4 名成员
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 521
