跳转到主内容
Canon PowerShot ELPH330 HS Camera Case Replacement
你所需要的
  1. Canon PowerShot ELPH330 HS Camera Case Replacement, Camera Case: 步骤 1 中的图像 1,2 Canon PowerShot ELPH330 HS Camera Case Replacement, Camera Case: 步骤 1 中的图像 2,2
    • On the top-center of your device, turn off the camera by pressing the power button.
    • Put your finger on the battery door and slide the battery door to the right which will then open the door.
    • Push the release button downward and it will release the battery.
  2. Canon PowerShot ELPH330 HS Camera Case Replacement: 步骤 2 中的图像 1,1
    • Use the Phillips #00 screwdriver to remove the two screws.
  3. Canon PowerShot ELPH330 HS Camera Case Replacement: 步骤 3 中的图像 1,1
    • Remove two more screws using the Phillips #00 screwdriver.
  4. Canon PowerShot ELPH330 HS Camera Case Replacement: 步骤 4 中的图像 1,1
    • On the lower right side of the camera case, remove the single screw using Phillips #00 screwdriver.
    • On the upper right side of the camera, remove the HDMI A/V out port.
    • Beneath the port cover, remove the screw using the same Phillips #00 screwdriver.
  5. Canon PowerShot ELPH330 HS Camera Case Replacement: 步骤 5 中的图像 1,1
    • Using your fingers, carefully pry the case apart at the seam.
结论
Michelle Ngo
于07/23/19注册
595 声望
创作了3篇指南
团队
UW Tacoma, Team S1-G3, Liner Summer 2019 UW Tacoma, Team S1-G3, Liner Summer 2019 的会员
UWT-LINER-SU19S1G3
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 197
