跳转到主内容
Canon PowerShot ELPH330 HS Camera Repair LCD Screen Replacement
你所需要的
  1. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement, LCD Screen: 步骤 1 中的图像 1,2 Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement, LCD Screen: 步骤 1 中的图像 2,2
    • Turn off your camera.
    • Remove the battery.
    • Slide the battery door open with the rubber pad on the bottom right side of the camera.
    • Remove the battery by pushing down on the release button.
  2. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: 步骤 2 中的图像 1,1
    • Remove the two screws on the left side with a Phillips #00 screwdriver.
  3. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: 步骤 3 中的图像 1,1
    • Remove the two screws on the bottom of the camera with a Phillips #00 screwdriver.
  4. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: 步骤 4 中的图像 1,1
    • Remove the two screws on the right side with a Phillips #00 screwdriver.
  5. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: 步骤 5 中的图像 1,1
    • Using your fingers, carefully pry the case apart at the seam.
  6. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: 步骤 6 中的图像 1,2 Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: 步骤 6 中的图像 2,2
    • Flip the camera over so that the lens is facing you.
    • Disconnect the highlighted port from the motherboard.
  7. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: 步骤 7 中的图像 1,2 Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: 步骤 7 中的图像 2,2
    • Remove the bracket around the LCD screen.
  8. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: 步骤 8 中的图像 1,1
    • Using the spudger, carefully pry the top to remove the LCD screen.
结论
Michelle Ngo
于07/23/19注册
595 声望
创作了3篇指南
团队
UW Tacoma, Team S1-G3, Liner Summer 2019 UW Tacoma, Team S1-G3, Liner Summer 2019 的会员
UWT-LINER-SU19S1G3
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 26
总计 515
