跳转到主内容
Canon PowerShot ELPH 310 HS External Panels Replacement
你所需要的
  1. Canon PowerShot ELPH 310 HS External Panels Replacement, External Panels: 步骤 1 中的图像 1,1
    • Use the Phillips #000 screwdriver from the iFixit tool kit to unscrew the two image stabilizer panel’s 2 mm Phillips head screws.
    • Using your hands, remove the image stabilizer panel.
  2. Canon PowerShot ELPH 310 HS External Panels Replacement: 步骤 2 中的图像 1,2 Canon PowerShot ELPH 310 HS External Panels Replacement: 步骤 2 中的图像 2,2
    • Unscrew the two 4 mm Phillips head screws from the bottom side of the camera.
  3. Canon PowerShot ELPH 310 HS External Panels Replacement: 步骤 3 中的图像 1,2 Canon PowerShot ELPH 310 HS External Panels Replacement: 步骤 3 中的图像 2,2
    • Using your hand, open the battery portal located on the bottom left of the camera. The screw is in the bottom left of the battery portal.
    • Unscrew the hidden 4mm Phillips head screw inside the battery portal.
  4. Canon PowerShot ELPH 310 HS External Panels Replacement: 步骤 4 中的图像 1,2 Canon PowerShot ELPH 310 HS External Panels Replacement: 步骤 4 中的图像 2,2
    • Remove the HDMI side panel with your hands.
    • Unscrew the four 4 mm Phillips head screws from the inside of the camera.
  5. Canon PowerShot ELPH 310 HS External Panels Replacement: 步骤 5 中的图像 1,1
    • The back side of the camera should pop off or be removed by hand.
  6. Canon PowerShot ELPH 310 HS External Panels Replacement: 步骤 6 中的图像 1,2 Canon PowerShot ELPH 310 HS External Panels Replacement: 步骤 6 中的图像 2,2
    • Unscrew the one 3 mm Phillips head screw on the top of the camera.
  7. Canon PowerShot ELPH 310 HS External Panels Replacement: 步骤 7 中的图像 1,1
    • Manually remove the front panel from the camera.
结论
一条评论
I have lost the two 4mm screws from the bottom of the camera and would like to buy replacements. Does anyone know the exact size of these screws?
Holland Van Ackeren - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 14
总计 437
