跳转到主内容
Canon PowerShot ELPH 300HS Camera Case Replacement
你所需要的
    • Before you begin taking apart your device, the first, and MOST IMPORTANT STEPS are to:
    • Turn off your camera.
    • Remove the battery to prevent risk of shock.
  1. Canon PowerShot ELPH 300HS Camera Case Replacement, Remove the Battery: 步骤 2 中的图像 1,2 Canon PowerShot ELPH 300HS Camera Case Replacement, Remove the Battery: 步骤 2 中的图像 2,2
    • Turn off your camera by pressing the power button, located on the top-center of the device.
    • Locate the battery door on the bottom right area of the camera case.
    • Place your finger firmly on the black rubber pad on the battery door and slide the door to the right to open it.
    • Locate the orange battery release button beneath the battery door.
    • Slide the battery release button downward to release the battery.
  2. Canon PowerShot ELPH 300HS Camera Case Replacement, Left Side Screws: 步骤 3 中的图像 1,1
    • Be careful when removing screws, as they are stripped easily.
    • Remove the two screws located on the left side of the camera case, using the Phillips screwdriver #00 (2.0 mm).
  3. Canon PowerShot ELPH 300HS Camera Case Replacement, Bottom Screws: 步骤 4 中的图像 1,1
    • Remove the two screws on the bottom of the camera located near the battery door (Phillips #00 screwdriver) (4.0 mm).
  4. Canon PowerShot ELPH 300HS Camera Case Replacement, Right Side Screws: 步骤 5 中的图像 1,1
    • Remove the screw located on the lower right side of the camera case (Phillips #00 screwdriver) (4.0 mm).
    • Remove the HDMI A/V out port cover located on the upper right side of the camera.
    • Remove the screw located just beneath the port cover removed in step 2. (Phillips #00 screwdriver) (2.0 mm).
  5. Canon PowerShot ELPH 300HS Camera Case Replacement: 步骤 6 中的图像 1,1
    • Remove the back portion of the camera case to reveal the screw located on the top of the case.
    • Remove the screw from the top of camera case, located next to the shutter button (Phillips #00 screwdriver) (1.5 mm).
  6. Canon PowerShot ELPH 300HS Camera Case Replacement, Remove the Case from the Camera: 步骤 7 中的图像 1,3 Canon PowerShot ELPH 300HS Camera Case Replacement, Remove the Case from the Camera: 步骤 7 中的图像 2,3 Canon PowerShot ELPH 300HS Camera Case Replacement, Remove the Case from the Camera: 步骤 7 中的图像 3,3
    • Carefully pry the case apart at the seem, using your fingers.
    • Be careful not to over bend the small metal projections located along the seams. These aid in holding the case together.
    • Be careful not to allow dust or other particles to settle inside of the camera while the case is detached. This can cause functional issues in the future.
结论
另外一个人完成了本指南。
团队
Michigan Tech, Team 5-6, Lauer Spring 2014 Michigan Tech, Team 5-6, Lauer Spring 2014 的会员
MTU-LAUER-S14S5G6
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 901
