跳转到主内容
Canon PowerShot ELPH 150 IS LCD Screen Replacement
你所需要的
  1. Canon PowerShot ELPH 150 IS LCD Screen Replacement, Back Plate/Menu Buttons: 步骤 1 中的图像 1,2 Canon PowerShot ELPH 150 IS LCD Screen Replacement, Back Plate/Menu Buttons: 步骤 1 中的图像 2,2
    • Locate the ON/Off button on the top of the camera and hold it down until the screen and all lights on the camera go dark.
  2. Canon PowerShot ELPH 150 IS LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Locate the back plate of the camera (contains the LCD screen and menu buttons).
  3. Canon PowerShot ELPH 150 IS LCD Screen Replacement: 步骤 3 中的图像 1,2 Canon PowerShot ELPH 150 IS LCD Screen Replacement: 步骤 3 中的图像 2,2
    • To remove the back plate you will need to unscrew the 6 support screws securing it to the camera.
    • Use a Phillips #00 screwdriver to remove the first 2 screws on the bottom of the camera.
  4. Canon PowerShot ELPH 150 IS LCD Screen Replacement: 步骤 4 中的图像 1,3 Canon PowerShot ELPH 150 IS LCD Screen Replacement: 步骤 4 中的图像 2,3 Canon PowerShot ELPH 150 IS LCD Screen Replacement: 步骤 4 中的图像 3,3
    • Remove the next 2 screws located behind the AV port using the same Phillips #00 screwdriver.
  5. Canon PowerShot ELPH 150 IS LCD Screen Replacement: 步骤 5 中的图像 1,2 Canon PowerShot ELPH 150 IS LCD Screen Replacement: 步骤 5 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the final 2 screws from the blue side panel.
  6. Canon PowerShot ELPH 150 IS LCD Screen Replacement: 步骤 6 中的图像 1,3 Canon PowerShot ELPH 150 IS LCD Screen Replacement: 步骤 6 中的图像 2,3 Canon PowerShot ELPH 150 IS LCD Screen Replacement: 步骤 6 中的图像 3,3
    • Use your hands or a spudger to gently pry the front and back case apart along the seams on the bottom of the camera.
    • Completely remove the back plate.
  7. Canon PowerShot ELPH 150 IS LCD Screen Replacement, LCD Screen: 步骤 7 中的图像 1,1
    • Once the back plate and face plate have been removed, you can begin to remove the LCD screen.
  8. Canon PowerShot ELPH 150 IS LCD Screen Replacement: 步骤 8 中的图像 1,2 Canon PowerShot ELPH 150 IS LCD Screen Replacement: 步骤 8 中的图像 2,2
    • Turn the camera so that the LCD screen is facing you.
    • Remove the 2 screws on the silver plate to the right of the screen using the PH00 screw driver head.
  9. Canon PowerShot ELPH 150 IS LCD Screen Replacement: 步骤 9 中的图像 1,3 Canon PowerShot ELPH 150 IS LCD Screen Replacement: 步骤 9 中的图像 2,3 Canon PowerShot ELPH 150 IS LCD Screen Replacement: 步骤 9 中的图像 3,3
    • Gently remove the silver plate by pulling it back towards you as you hold the camera firmly in the other hand.
    • With the plate removed you will be able to locate the electrical ribbon that connect the LCD screen to the device.
    • You will also be able to lift the LCD screen away from the motherboard cover as picture in image 3. It will still be attached via electrical ribbon but can be moved to the side so you can access the clip underneath.
  10. Canon PowerShot ELPH 150 IS LCD Screen Replacement: 步骤 10 中的图像 1,2 Canon PowerShot ELPH 150 IS LCD Screen Replacement: 步骤 10 中的图像 2,2
    • With the screen off to the side, and the horizontal electrical ribbon attached to it out of the way, gently lift the vertical electrical transducer ribbon to expose the salmon colored clip holding the horizontal ribbon in place.
  11. Canon PowerShot ELPH 150 IS LCD Screen Replacement: 步骤 11 中的图像 1,2 Canon PowerShot ELPH 150 IS LCD Screen Replacement: 步骤 11 中的图像 2,2
    • Pull the clip away from the horizontal electrical ribbon to unlock it.
    • Gently pull the horizontal electrical ribbon out of the clip to remove the LCD screen completely. Go slowly so you do no rip the ribbon or damage the clip or exposed motherboard beneath it.
结论
Alex Larrimore
于03/05/17注册
314 声望
创作了3篇指南
团队
1指南评论
Great tutorial! Where can I buy the screen? I contacted Canon and they said they don't sell these parts; they just replace the cameras that are sent in with broken screens.
gravity1015 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 29
总计 1,894
