跳转到主内容
加入维修社区 - 创建账户
Canon PowerShot A80 Back Cover Replacement
你所需要的
  1. Canon PowerShot A80 Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Remove the three Phillips #00 screws from the bottom of the camera.
  2. Canon PowerShot A80 Back Cover Replacement: 步骤 2 中的图像 1,2 Canon PowerShot A80 Back Cover Replacement: 步骤 2 中的图像 2,2
    • Open the door to the CompactFlash memory card slot by sliding it towards you and swinging it open.
    • Remove the memory card if it is still in the camera.
    • Use the Phillips #00 screwdriver to remove the single screw underneath the memory card slot door.
  3. Canon PowerShot A80 Back Cover Replacement: 步骤 3 中的图像 1,1
    • Remove the Phillips #00 screw located inside the top of the memory card compartment.
  4. Canon PowerShot A80 Back Cover Replacement: 步骤 4 中的图像 1,2 Canon PowerShot A80 Back Cover Replacement: 步骤 4 中的图像 2,2
    • Open the battery compartment door at the bottom of the camera by sliding the latch to the right and then sliding the door down.
    • Remove the batteries from the compartment.
    • Remove the three Phillips #00 screws located inside the battery compartment.
    • The screw on the left is longer than the other two.
  5. Canon PowerShot A80 Back Cover Replacement: 步骤 5 中的图像 1,1
    • Remove the top lid of the camera.
    • Be cautious of the fragile mylar cable that connects the lid to the main body of the camera.
    • Removing the lid takes a little force. Do this gently. There may be a snapping sound.
    • The door to the memory card compartment will be freed and should be removable now.
    • In other versions of this camera, there is a tab that secures the top from the wrist strap. If yours has this, you won't be able to completely separate the top until you have removed the top screw in Step 8.
  6. Canon PowerShot A80 Back Cover Replacement: 步骤 6 中的图像 1,1
    • Remove the two Phillips #00 screws from the side of the camera.
    • Open the small rubber door below this screw that covers the connectors.
  7. Canon PowerShot A80 Back Cover Replacement: 步骤 7 中的图像 1,2 Canon PowerShot A80 Back Cover Replacement: 步骤 7 中的图像 2,2
    • Open and pivot the LCD screen to its widest open position.
    • Remove the rear cover by pulling it straight away from the body of the camera.
    • When reassembling the camera, remember to replace the screws in the same location from which you removed them. Otherwise, you may damage the camera.
结论
konrad
于01/11/11注册
220 声望
创作了3篇指南
团队
Cal Poly, Team 7-31, Regan Winter 2011 Cal Poly, Team 7-31, Regan Winter 2011 的会员
CPSU-REGAN-W11S7G31
6 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 18
过去 30 天: 70
总计 5,779
