跳转到主内容
Canon PowerShot A75 Speaker Replacement
你所需要的
  1. Canon PowerShot A75 Speaker Replacement, Batteries: 步骤 1 中的图像 1,1
    • Turn the camera over and locate the "BATT OPEN" sliding switch.
  2. Canon PowerShot A75 Speaker Replacement: 步骤 2 中的图像 1,3 Canon PowerShot A75 Speaker Replacement: 步骤 2 中的图像 2,3 Canon PowerShot A75 Speaker Replacement: 步骤 2 中的图像 3,3
    • Slide the switch to the right.
    • The battery cover should slide down and spring open.
  3. Canon PowerShot A75 Speaker Replacement: 步骤 3 中的图像 1,3 Canon PowerShot A75 Speaker Replacement: 步骤 3 中的图像 2,3 Canon PowerShot A75 Speaker Replacement: 步骤 3 中的图像 3,3
    • Remove the 4 AA batteries.
    • Watch for the orientation of the batteries as they slide out.
    • The battery orientation is shown under the battery flap itself and on a sticker next to the battery flap.
  4. Canon PowerShot A75 Speaker Replacement, Speaker: 步骤 4 中的图像 1,2 Canon PowerShot A75 Speaker Replacement, Speaker: 步骤 4 中的图像 2,2
    • Open the memory card slot by sliding it laterally until you hear a click
    • Remove the 5.9mm screw in the upper corner of the memory card slot
  5. Canon PowerShot A75 Speaker Replacement: 步骤 5 中的图像 1,1
    • Remove the two 4.1mm screws at the bottom of the battery flap.
  6. Canon PowerShot A75 Speaker Replacement: 步骤 6 中的图像 1,2 Canon PowerShot A75 Speaker Replacement: 步骤 6 中的图像 2,2
    • Lift the shutter button and speaker part from the top of the camera.
    • Do not pull the part too hard because there is a plug connecting the speaker to the camera.
  7. Canon PowerShot A75 Speaker Replacement: 步骤 7 中的图像 1,3 Canon PowerShot A75 Speaker Replacement: 步骤 7 中的图像 2,3 Canon PowerShot A75 Speaker Replacement: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    • Using a pair of tweezers, grab the plug that connects the speaker to the camera and gently pull it out.
  8. Canon PowerShot A75 Speaker Replacement: 步骤 8 中的图像 1,1
    • Do not proceed to the next step unless you have previous soldering experience because you can damage the flash unit if you are not careful.
    • Remove the glue and unsolder the speaker from the outer casing. Replace or repair the speaker as necessary.
结论
Austin Fox
于04/11/12注册
1 声望
创作了2篇指南
团队
Cal Poly, Team 17-30, Amido Spring 2012 Cal Poly, Team 17-30, Amido Spring 2012 的会员
CPSU-AMIDO-S12S17G30
5 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 426
