跳转到主内容
Canon PowerShot A75 Casing Replacement
你所需要的
  1. Canon PowerShot A75 Casing Replacement, Batteries: 步骤 1 中的图像 1,1
    • Turn the camera over and locate the "BATT OPEN" sliding switch.
  2. Canon PowerShot A75 Casing Replacement: 步骤 2 中的图像 1,3 Canon PowerShot A75 Casing Replacement: 步骤 2 中的图像 2,3 Canon PowerShot A75 Casing Replacement: 步骤 2 中的图像 3,3
    • Slide the switch to the right.
    • The battery cover should slide down and spring open.
  3. Canon PowerShot A75 Casing Replacement: 步骤 3 中的图像 1,3 Canon PowerShot A75 Casing Replacement: 步骤 3 中的图像 2,3 Canon PowerShot A75 Casing Replacement: 步骤 3 中的图像 3,3
    • Remove the 4 AA batteries.
    • Watch for the orientation of the batteries as they slide out.
    • The battery orientation is shown under the battery flap itself and on a sticker next to the battery flap.
  4. Canon PowerShot A75 Casing Replacement, Casing: 步骤 4 中的图像 1,1
    • Remove the three 2.5mm screws on the bottom of the camera.
  5. Canon PowerShot A75 Casing Replacement: 步骤 5 中的图像 1,1
    • Remove the 3.8mm screw underneath the flap that covers the A/V port.
  6. Canon PowerShot A75 Casing Replacement: 步骤 6 中的图像 1,2 Canon PowerShot A75 Casing Replacement: 步骤 6 中的图像 2,2
    • Remove the 2.4mm screw located underneath the cover of the memory card slot.
  7. Canon PowerShot A75 Casing Replacement: 步骤 7 中的图像 1,2 Canon PowerShot A75 Casing Replacement: 步骤 7 中的图像 2,2
    • Open the memory card slot by sliding it laterally until you hear a click.
    • Remove the 5.9mm screw in the upper corner of the memory card slot.
  8. Canon PowerShot A75 Casing Replacement: 步骤 8 中的图像 1,1
    • Remove the two 4.1mm screws at the bottom of the battery flap.
  9. Canon PowerShot A75 Casing Replacement: 步骤 9 中的图像 1,2 Canon PowerShot A75 Casing Replacement: 步骤 9 中的图像 2,2
    • Lift the shutter button and speaker part from the top of the camera.
    • DO NOT pull the part too hard because there is a plug connecting the speaker to the camera.
  10. Canon PowerShot A75 Casing Replacement: 步骤 10 中的图像 1,3 Canon PowerShot A75 Casing Replacement: 步骤 10 中的图像 2,3 Canon PowerShot A75 Casing Replacement: 步骤 10 中的图像 3,3
    • Using a pair of tweezers, grab the plug that connects the speaker to the camera and gently pull it out.
  11. Canon PowerShot A75 Casing Replacement: 步骤 11 中的图像 1,1
    • Remove the rightmost 4.2mm screw underneath the battery cover, not the center screw.
  12. Canon PowerShot A75 Casing Replacement: 步骤 12 中的图像 1,3 Canon PowerShot A75 Casing Replacement: 步骤 12 中的图像 2,3 Canon PowerShot A75 Casing Replacement: 步骤 12 中的图像 3,3
    • Separate the back casing and front casing of the camera using your hands.
    • Pulling the two halves apart can be difficult, especially at the top. Use a moderate amount of force.
  13. Canon PowerShot A75 Casing Replacement: 步骤 13 中的图像 1,3 Canon PowerShot A75 Casing Replacement: 步骤 13 中的图像 2,3 Canon PowerShot A75 Casing Replacement: 步骤 13 中的图像 3,3
    • On the front of the camera, press the button on the lower left of the lens.
    • Twist the outer lens casing counter-clockwise and slide it out.
  14. Canon PowerShot A75 Casing Replacement: 步骤 14 中的图像 1,3 Canon PowerShot A75 Casing Replacement: 步骤 14 中的图像 2,3 Canon PowerShot A75 Casing Replacement: 步骤 14 中的图像 3,3
    • Take off the front casing.
    • There is a black rubber washer around the lens that comes out after you take the casing off. Make sure to replace it when putting the camera back together.
结论
4等其他人完成本指南。
团队
Cal Poly, Team 17-30, Amido Spring 2012 Cal Poly, Team 17-30, Amido Spring 2012 的会员
CPSU-AMIDO-S12S17G30
5 名成员
创作了12篇指南
一条评论
Thank you for this detailed guide. It helped me to gain access to the electrical contacts in the battery compartment to remove alkaline battery corrosion
Jef B - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 1,481
