跳转到主内容
Canon PowerShot A75 Batteries Replacement
  1. Canon PowerShot A75 Batteries Replacement, Batteries: 步骤 1 中的图像 1,1
    • Turn the camera over and locate the "BATT OPEN" sliding switch.
  2. Canon PowerShot A75 Batteries Replacement: 步骤 2 中的图像 1,3 Canon PowerShot A75 Batteries Replacement: 步骤 2 中的图像 2,3 Canon PowerShot A75 Batteries Replacement: 步骤 2 中的图像 3,3
    • Slide the switch to the right.
    • The battery cover should slide down and spring open.
  3. Canon PowerShot A75 Batteries Replacement: 步骤 3 中的图像 1,3 Canon PowerShot A75 Batteries Replacement: 步骤 3 中的图像 2,3 Canon PowerShot A75 Batteries Replacement: 步骤 3 中的图像 3,3
    • Remove the 4 AA batteries.
    • Watch for the orientation of the batteries as they slide out.
    • The battery orientation is shown under the battery flap itself and on a sticker next to the battery flap.
结论
Put in fresh batteries. Gently shut the flap and slide it forward until you hear a click.
团队
Cal Poly, Team 17-30, Amido Spring 2012 Cal Poly, Team 17-30, Amido Spring 2012 的会员
CPSU-AMIDO-S12S17G30
5 名成员
创作了12篇指南
3条评论
Hi, there is a problem with my Powershot a75. Whenever I switch it on, it just says change the batteries even though they are either new, or fully charged. Thanks
Harry collier - 回复
had same trouble i fix it buy pressing the print button on back next to the disp button it should work then
hot5 - 回复
Probably you have change backup battery which is rechargeable and not easy to change. It is close to chargeable outlet.
Maganbhai Patel - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 37
总计 1,788
