跳转到主内容
Canon PowerShot A630 Shooting Mode Dial Replacement
你所需要的
  1. Canon PowerShot A630 Shooting Mode Dial Replacement, Front Panel: 步骤 1 中的图像 1,2 Canon PowerShot A630 Shooting Mode Dial Replacement, Front Panel: 步骤 1 中的图像 2,2
    • Open the battery door by sliding the tab on the battery door while pushing the battery door away from the camera.
    • Remove batteries.
  2. Canon PowerShot A630 Shooting Mode Dial Replacement: 步骤 2 中的图像 1,2 Canon PowerShot A630 Shooting Mode Dial Replacement: 步骤 2 中的图像 2,2
    • Remove the three indicated .2mm screws using a Phillips #00 screwdriver.
    • Gently pull off side-panel to remove it.
  3. Canon PowerShot A630 Shooting Mode Dial Replacement: 步骤 3 中的图像 1,1
    • Remove the two indicated .2mm screws using a Phillips #00 screwdriver.
  4. Canon PowerShot A630 Shooting Mode Dial Replacement: 步骤 4 中的图像 1,2 Canon PowerShot A630 Shooting Mode Dial Replacement: 步骤 4 中的图像 2,2
    • Remove the indicated .2mm screw using a Phillips #00 screwdriver.
    • Remove the three .2mm screws located on the internal side of the top panel within the battery chamber using a Phillips #00 screwdriver.
  5. Canon PowerShot A630 Shooting Mode Dial Replacement: 步骤 5 中的图像 1,2 Canon PowerShot A630 Shooting Mode Dial Replacement: 步骤 5 中的图像 2,2
    • Open 'DIGITAL A/V OUT' door on camera.
  6. Canon PowerShot A630 Shooting Mode Dial Replacement: 步骤 6 中的图像 1,1
    • Grip the sides of the top panel and gently pull to separate the top panel from the camera body.
    • The top panel will not completely detach.
  7. Canon PowerShot A630 Shooting Mode Dial Replacement: 步骤 7 中的图像 1,2 Canon PowerShot A630 Shooting Mode Dial Replacement: 步骤 7 中的图像 2,2
    • Gently pull the front and back panels apart, and use a Phillips #00 screwdriver to remove the screw connecting the panels.
    • Gripping the top and bottom, gently pull the front panel away from the camera body to remove it.
  8. Canon PowerShot A630 Shooting Mode Dial Replacement, Shooting Mode Dial: 步骤 8 中的图像 1,2 Canon PowerShot A630 Shooting Mode Dial Replacement, Shooting Mode Dial: 步骤 8 中的图像 2,2
    • Pry open the connector on the yellow ribbon cable using a plastic opening tool.
  9. Canon PowerShot A630 Shooting Mode Dial Replacement: 步骤 9 中的图像 1,1
    • Remove the 2 mm screws from the metal plate.
  10. Canon PowerShot A630 Shooting Mode Dial Replacement: 步骤 10 中的图像 1,1
    • Pull away the metal plate, exposing the underbelly of the mode dial.
    • Be careful not to pull too hard. Metal plate should remain attached.
  11. Canon PowerShot A630 Shooting Mode Dial Replacement: 步骤 11 中的图像 1,2 Canon PowerShot A630 Shooting Mode Dial Replacement: 步骤 11 中的图像 2,2
    • Remove the 2mm screw using the #00 Phillips screwdriver.
    • The mode dial should fall out.
结论
另外一个人完成了本指南。
Alicia Burns
于10/13/14注册
574 声望
创作了5篇指南
团队
Clemson, Team 2-5, Benson Fall 2014 Clemson, Team 2-5, Benson Fall 2014 的会员
CLEM-BENSON-F14S2G5
4 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 12
总计 538
