跳转到主内容
Canon PowerShot A630 Front Panel Replacement
你所需要的
  1. Canon PowerShot A630 Front Panel Replacement, Front Panel: 步骤 1 中的图像 1,2 Canon PowerShot A630 Front Panel Replacement, Front Panel: 步骤 1 中的图像 2,2
    • Open the battery door by sliding the tab on the battery door while pushing the battery door away from the camera.
    • Remove batteries.
  2. Canon PowerShot A630 Front Panel Replacement: 步骤 2 中的图像 1,2 Canon PowerShot A630 Front Panel Replacement: 步骤 2 中的图像 2,2
    • Remove the three indicated .2mm screws using a Phillips #00 screwdriver.
    • Gently pull off side-panel to remove it.
  3. Canon PowerShot A630 Front Panel Replacement: 步骤 3 中的图像 1,1
    • Remove the two indicated .2mm screws using a Phillips #00 screwdriver.
  4. Canon PowerShot A630 Front Panel Replacement: 步骤 4 中的图像 1,2 Canon PowerShot A630 Front Panel Replacement: 步骤 4 中的图像 2,2
    • Remove the indicated .2mm screw using a Phillips #00 screwdriver.
    • Remove the three .2mm screws located on the internal side of the top panel within the battery chamber using a Phillips #00 screwdriver.
  5. Canon PowerShot A630 Front Panel Replacement: 步骤 5 中的图像 1,2 Canon PowerShot A630 Front Panel Replacement: 步骤 5 中的图像 2,2
    • Open 'DIGITAL A/V OUT' door on camera.
  6. Canon PowerShot A630 Front Panel Replacement: 步骤 6 中的图像 1,1
    • Grip the sides of the top panel and gently pull to separate the top panel from the camera body.
    • The top panel will not completely detach.
  7. Canon PowerShot A630 Front Panel Replacement: 步骤 7 中的图像 1,2 Canon PowerShot A630 Front Panel Replacement: 步骤 7 中的图像 2,2
    • Gently pull the front and back panels apart, and use a Phillips #00 screwdriver to remove the screw connecting the panels.
    • Gripping the top and bottom, gently pull the front panel away from the camera body to remove it.
结论
2等其他人完成本指南。
Kelly Duggan
于10/13/14注册
442 声望
创作了3篇指南
团队
Clemson, Team 2-5, Benson Fall 2014 Clemson, Team 2-5, Benson Fall 2014 的会员
CLEM-BENSON-F14S2G5
4 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 16
总计 764
