跳转到主内容
加入维修社区 - 创建账户
Canon PowerShot A630 Back Panel Replacement
你所需要的
  1. Canon PowerShot A630 Back Panel Replacement, Front Panel: 步骤 1 中的图像 1,2 Canon PowerShot A630 Back Panel Replacement, Front Panel: 步骤 1 中的图像 2,2
    • Open the battery door by sliding the tab on the battery door while pushing the battery door away from the camera.
    • Remove batteries.
  2. Canon PowerShot A630 Back Panel Replacement: 步骤 2 中的图像 1,2 Canon PowerShot A630 Back Panel Replacement: 步骤 2 中的图像 2,2
    • Remove the three indicated .2mm screws using a Phillips #00 screwdriver.
    • Gently pull off side-panel to remove it.
  3. Canon PowerShot A630 Back Panel Replacement: 步骤 3 中的图像 1,1
    • Remove the two indicated .2mm screws using a Phillips #00 screwdriver.
  4. Canon PowerShot A630 Back Panel Replacement: 步骤 4 中的图像 1,2 Canon PowerShot A630 Back Panel Replacement: 步骤 4 中的图像 2,2
    • Remove the indicated .2mm screw using a Phillips #00 screwdriver.
    • Remove the three .2mm screws located on the internal side of the top panel within the battery chamber using a Phillips #00 screwdriver.
  5. Canon PowerShot A630 Back Panel Replacement: 步骤 5 中的图像 1,2 Canon PowerShot A630 Back Panel Replacement: 步骤 5 中的图像 2,2
    • Open 'DIGITAL A/V OUT' door on camera.
  6. Canon PowerShot A630 Back Panel Replacement: 步骤 6 中的图像 1,1
    • Grip the sides of the top panel and gently pull to separate the top panel from the camera body.
    • The top panel will not completely detach.
  7. Canon PowerShot A630 Back Panel Replacement: 步骤 7 中的图像 1,2 Canon PowerShot A630 Back Panel Replacement: 步骤 7 中的图像 2,2
    • Gently pull the front and back panels apart, and use a Phillips #00 screwdriver to remove the screw connecting the panels.
    • Gripping the top and bottom, gently pull the front panel away from the camera body to remove it.
  8. Canon PowerShot A630 Back Panel Replacement, Back Panel: 步骤 8 中的图像 1,2 Canon PowerShot A630 Back Panel Replacement, Back Panel: 步骤 8 中的图像 2,2
    • Use the spudger to gently pull back the retaining clip and pull the ribbon out.
    • The top panel should now be completely detached from the camera.
    • Applying too much force to the spudger may damage the retaining clip.
  9. Canon PowerShot A630 Back Panel Replacement: 步骤 9 中的图像 1,2 Canon PowerShot A630 Back Panel Replacement: 步骤 9 中的图像 2,2
    • Remove .2 mm screw using a #00 Philips screwdriver.
    • Gently pry off back panel to remove it.
结论
另外一个人完成了本指南。
Alicia Burns
于10/13/14注册
645 声望
创作了5篇指南
团队
Clemson, Team 2-5, Benson Fall 2014 Clemson, Team 2-5, Benson Fall 2014 的会员
CLEM-BENSON-F14S2G5
4 名成员
创作了18篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 31
总计 1,540
