跳转到主内容
Canon PowerShot A620 Shutter Button Replacement
Jaime Abraham
Jaime Abraham3 其他贡献者
最后更新于 March 21, 2020
15 - 30 分钟
中等
需要更好的图片
更好的介绍
你所需要的
工具
  1. Canon PowerShot A620 Shutter Button Replacement, Side Panel: 步骤 1 中的图像 1,3 Canon PowerShot A620 Shutter Button Replacement, Side Panel: 步骤 1 中的图像 2,3 Canon PowerShot A620 Shutter Button Replacement, Side Panel: 步骤 1 中的图像 3,3
    • Unscrew the three Phillips #00 1.6x3mm screws on the side.
    • Lift loose panel from the case.
    • Unscrew the two Phillips #00 1.6x3mm screws that were previously hidden beneath the panel.
  2. Canon PowerShot A620 Shutter Button Replacement, Bottom Panel: 步骤 2 中的图像 1,1
    • Unscrew the two Phillips #00 1.6x3mm screws on the bottom panel.
  3. Canon PowerShot A620 Shutter Button Replacement, Battery Compartment: 步骤 3 中的图像 1,1
    • Open the battery door.
    • Unscrew the four Phillips #00 1.6x3mm screws in the battery compartment.
  4. Canon PowerShot A620 Shutter Button Replacement, Terminal Cover: 步骤 4 中的图像 1,2 Canon PowerShot A620 Shutter Button Replacement, Terminal Cover: 步骤 4 中的图像 2,2
    • Lift the terminal cover on the side of the camera.
    • Unscrew the three Phillips #00 1.6x3mm screws beneath the terminal cover.
  5. Canon PowerShot A620 Shutter Button Replacement, Top Panel: 步骤 5 中的图像 1,1
    • Gently pull the top panel to separate it from the case.
    • Although the top panel will now be free from the rest of the case, it will still be attached to the camera by a ribbon cable.
  6. Canon PowerShot A620 Shutter Button Replacement, Front Panel: 步骤 6 中的图像 1,2 Canon PowerShot A620 Shutter Button Replacement, Front Panel: 步骤 6 中的图像 2,2
    • Gently pull the front panel to separate it from the camera.
    • The battery terminals are easy to access from this step.
  7. Canon PowerShot A620 Shutter Button Replacement, Terminal Cover: 步骤 7 中的图像 1,2 Canon PowerShot A620 Shutter Button Replacement, Terminal Cover: 步骤 7 中的图像 2,2
    • Gently pull the terminal cover to separate it from the camera.
  8. Canon PowerShot A620 Shutter Button Replacement, Memory Card Cover: 步骤 8 中的图像 1,2 Canon PowerShot A620 Shutter Button Replacement, Memory Card Cover: 步骤 8 中的图像 2,2
    • Slide the memory card cover down.
    • Unscrew the Phillips #00 1.6x3mm screw beneath the memory card cover.
  9. Canon PowerShot A620 Shutter Button Replacement, Back Panel: 步骤 9 中的图像 1,2 Canon PowerShot A620 Shutter Button Replacement, Back Panel: 步骤 9 中的图像 2,2
    • Gently pull the back panel to separate it from the camera.
  10. Canon PowerShot A620 Shutter Button Replacement, Metal Plate Screws: 步骤 10 中的图像 1,2 Canon PowerShot A620 Shutter Button Replacement, Metal Plate Screws: 步骤 10 中的图像 2,2
    • Unscrew the Phillips #00 1.6x3mm screw located on the top panel.
  11. Canon PowerShot A620 Shutter Button Replacement, Metal Plate: 步骤 11 中的图像 1,1
    • Gently lift the metal plate and move it to the side.
  12. Canon PowerShot A620 Shutter Button Replacement, Trigger Button Screws: 步骤 12 中的图像 1,2 Canon PowerShot A620 Shutter Button Replacement, Trigger Button Screws: 步骤 12 中的图像 2,2
    • Unscrew the two Phillips #00 1.6x3mm screws that hold in the trigger button.
  13. Canon PowerShot A620 Shutter Button Replacement, Trigger Button: 步骤 13 中的图像 1,1
    • The trigger button will fall off once the screws have been removed.
结论
另外一个人完成了本指南。
Jaime Abraham
于09/08/14注册
350 声望
创作了3篇指南
团队
CSU Fullerton, Team 1-1, Bruce Fall 2014 CSU Fullerton, Team 1-1, Bruce Fall 2014 的会员
CSUF-BRUCE-F14S1G1
3 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 46
总计 1,472
