跳转到主内容
Canon PowerShot A610 Broken Control Buttons Repair
你所需要的
  1. Canon PowerShot A610 Broken Control Buttons Repair, Batteries: 步骤 1 中的图像 1,2 Canon PowerShot A610 Broken Control Buttons Repair, Batteries: 步骤 1 中的图像 2,2
    • Unlock the battery cover, while swinging the cover outward to open it.
  2. Canon PowerShot A610 Broken Control Buttons Repair: 步骤 2 中的图像 1,1
    • Turn the camera over and allow the batteries to fall out.
    • Close the battery cover.
  3. Canon PowerShot A610 Broken Control Buttons Repair, Camera Housing: 步骤 3 中的图像 1,3 Canon PowerShot A610 Broken Control Buttons Repair, Camera Housing: 步骤 3 中的图像 2,3 Canon PowerShot A610 Broken Control Buttons Repair, Camera Housing: 步骤 3 中的图像 3,3
    • Remove the three 3 mm screws that attach the side panel to the body of the camera.
    • Using your fingernails, pull the side panel outward to remove it.
    • Remove the two remaining 2 mm screws that attach to the frame of the camera.
  4. Canon PowerShot A610 Broken Control Buttons Repair: 步骤 4 中的图像 1,1
    • Remove the 3 mm screw that sits at the bottom of the camera, near the front side.
    • Remove the 4 mm screw that sits at the bottom of the camera, near the back side.
  5. Canon PowerShot A610 Broken Control Buttons Repair: 步骤 5 中的图像 1,1
    • Open the battery cover.
    • Remove the 5 mm screw that sits on the top of the battery slot.
    • Remove the three 6 mm screws that sit at the bottom of the battery slot.
  6. Canon PowerShot A610 Broken Control Buttons Repair: 步骤 6 中的图像 1,2 Canon PowerShot A610 Broken Control Buttons Repair: 步骤 6 中的图像 2,2
    • Open the digital A/V DC terminal cover.
    • Remove the three 4 mm screws.
    • Detach the digital A/V DC terminal.
    • When you reassemble the camera, leave the topmost screw out until after you put the top casing back.
  7. Canon PowerShot A610 Broken Control Buttons Repair: 步骤 7 中的图像 1,1
    • Grip the sides of the top cover and gently lift it until it detaches from the camera.
    • Do not completely remove the top cover; an orange ribbon cable still connects it to the camera.
  8. Canon PowerShot A610 Broken Control Buttons Repair: 步骤 8 中的图像 1,2 Canon PowerShot A610 Broken Control Buttons Repair: 步骤 8 中的图像 2,2
    • With the camera upside down, pull the side of the front case that is closest to you, in an outward movement.
    • Apply some force, but pull the front case gently to prevent damage.
  9. Canon PowerShot A610 Broken Control Buttons Repair: 步骤 9 中的图像 1,2 Canon PowerShot A610 Broken Control Buttons Repair: 步骤 9 中的图像 2,2
    • Open the memory card slot cover.
    • Remove the 3 mm screw that sits near the bottom of the case.
  10. Canon PowerShot A610 Broken Control Buttons Repair: 步骤 10 中的图像 1,3 Canon PowerShot A610 Broken Control Buttons Repair: 步骤 10 中的图像 2,3 Canon PowerShot A610 Broken Control Buttons Repair: 步骤 10 中的图像 3,3
    • Flip the LCD screen all the way open.
    • Grip both sides of top of the back case and gently pull it, in an outward movement, until the case detaches.
  11. Canon PowerShot A610 Broken Control Buttons Repair, Canon PowerShot A610 Broken Control Buttons Repair: 步骤 11 中的图像 1,2 Canon PowerShot A610 Broken Control Buttons Repair, Canon PowerShot A610 Broken Control Buttons Repair: 步骤 11 中的图像 2,2
    • Remove the back casing.
    • Flip the casing over and push on the back of the broken button with either your finger or a blunt object until it realigns into its slot.
结论
Matthew Ramirez
于01/20/11注册
625 声望
创作了5篇指南
团队
Cal Poly, Team 11-26, Maness Winter 2011 Cal Poly, Team 11-26, Maness Winter 2011 的会员
CPSU-MANESS-W11S11G26
3 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 5,237
