跳转到主内容
Canon PowerShot A590 IS Clock Battery Replacement
你所需要的
  1. Canon PowerShot A590 IS Clock Battery Replacement, Batteries: 步骤 1 中的图像 1,2 Canon PowerShot A590 IS Clock Battery Replacement, Batteries: 步骤 1 中的图像 2,2
    • The battery hatch is on the bottom of the camera.
    • CAUTION: Locate the switch to open the hatch and push gently toward the front of the camera. Too much force can break the hatch.
    • While the switch is pushed forward, pull the cover away from the camera.
    Can the hatch be replaced. The piece that holds the hatch is broken.
    alisonbforman46 - 回复
    I had this issue for some time and never realized that lithium battery was so easily accessible. Fixed my problem.
    Spud Head - 回复
  2. Canon PowerShot A590 IS Clock Battery Replacement: 步骤 2 中的图像 1,1
    • This camera requires AA batteries.
    • To remove batteries, simply allow them to fall out of the camera.
    • Use a fingernail to lift the clock battery out of the camera.
  3. Canon PowerShot A590 IS Clock Battery Replacement: 步骤 3 中的图像 1,1
    • When replacing the AA batteries, verify they are oriented correctly by following the (+) and (-) signs on the camera.
  4. Canon PowerShot A590 IS Clock Battery Replacement, Locate Clock Battery: 步骤 4 中的图像 1,1
    • To access the clock battery, find the clock battery cover, shown here in the red square.
  5. Canon PowerShot A590 IS Clock Battery Replacement, Remove Battery Tab: 步骤 5 中的图像 1,1
    • When accessing the clock battery, use a fingernail or similar small instrument to gently pull the tab out.
  6. Canon PowerShot A590 IS Clock Battery Replacement, Remove Battery from Tab: 步骤 6 中的图像 1,1
    • Now that you have the tab and battery removed, use a fingernail or other small tool to remove the battery from the tab.
    • This battery is a CR1220 type watch battery.
  7. Canon PowerShot A590 IS Clock Battery Replacement, Replacing Clock Battery: 步骤 7 中的图像 1,1
    • When replacing the clock battery, be sure to have the battery oriented properly, as shown in the picture.
    • Remember, the tab goes in with the exposed side of the battery facing towards the lens.
结论
13等其他人完成本指南。
Matt Wolfe
于10/11/10注册
405 声望
撰写一个指南
团队
Cal Poly, Team 9-19, Regan Fall 2010 Cal Poly, Team 9-19, Regan Fall 2010 的会员
CPSU-REGAN-F10S9G19
4 名成员
创作了14篇指南
9条评论
thanks its very useful forme
srikrishnan2003 - 回复
thank you, very useful for my old camera :)
agungsp2000 - 回复
Perfect! I never even knew I had this battery in there. Couldn't figure out why the date and time wouldn't stay set every time I shut it off. And then I found the answer here.
Thank you very much for the post!
sherlock261 - 回复
I'm a senior citizen and am not very good with modern technology. Been going crazy trying to set my clock in my digital camera. I didn't want to buy a new one because I have had this one for years (Power Shot A590) and didn't want to have to learn to use a newer one. Finally got smart enough to do a google search for an answer. Will get a new battery tomorrow and solve my problem. Thanks for the help!...the information age is good for something after all.
Pat Solomon - 回复
Wow this is a great site. I got the answer I needed right away. The instructions were clear, simple and correct. Thank you.
You are bookmarked.
jeffrey wales - 回复
Please has anyone got a clock battery holder for a powershot A590? Mine fell out somewhere
when the kids were using it Love the camera and would like to get it back in use
Email at acv@xtra.co.nz if you could help me
rgds Alan
Alan Vail - 回复
I had this annoying problem for two years and thought a lot of disassembly would be required to access this battery, so I lived with it. I was glad I came across this site and never realized that the lithium battery cover was so easily accessed. I easily replaced the CR1220 battery and now have my time/date back.
Spud Head - 回复
Bonjour, j'me nomme ATOULOUKOU, j'suis un utilisateur de l'appareil photo canon A580, ça fait un vieux que j'l'ai maintenant, Euuh j'me suis acheté une pile duracell, il y'a 2 jours de cela et j'ai remplacé les anciennes piles par les nouvelle mais j'constate que mon appel affiche tjrs la batterie faible et me conseille de changer les piles j'sais pas si ce sont les piles nouvellement achetée où bien l'appareil à un blême ( peut-être qu'il y'a une batterie incorporée à l'intérieur qui est faible ) bah j'sais pas, donc j'aimerais que vous m'aidez sur ce problème
Siméon atouloukou - 回复
Hello, my name is ATOULOUKOU, I am a user of the Canon A580 camera, it's been an old one that I have now, Uh, I bought myself a duracell battery, 2 days ago that and I replaced the old batteries with the new ones but I noticed that my call always shows the low battery and advises me to change the batteries I don't know if these are the newly purchased batteries or the device has a pale (maybe there is a built-in battery inside which is weak) well I don't know, so I would like you to help me with this problem
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 104
总计 14,599
