本指南有最近更改,您可查看未经巡查的最新版本。
简介
First, we will locate the battery/memory card hatch. Second, we will change the main batteries and orient them properly. Third, we will change the clock battery.
你所需要的
The battery hatch is on the bottom of the camera.
While the switch is pushed forward, pull the cover away from the camera.
This camera requires AA batteries. To remove batteries, simply allow them to fall out of the camera.
The clock battery cover is shown here in the purple circle. Use a fingernail to lift the battery out of the camera.
When replacing the AA batteries, verify they are oriented correctly by following the (+) and (-) signs on the camera.
To install new batteries and reassemble your device, follow these instructions in reverse order.
2等其他人完成本指南。
