本指南有最近更改,您可查看未经巡查的最新版本。
简介
You will remove screws from the bottom and sides of the camera in order to remove the cameras back cover.
你所需要的
Remove the screw located under the rubber flap on the left side of the camera using a magnetic screwdriver.
Remove the two screws located on the other side of the camera using a magnetic screwdriver
Remove the three screws located at the bottom of the camera using a magnetic screwdriver.
Open the battery cover.
Using the iPod tool, push up gently around all edges of the camera.
7等其他人完成本指南。
一条评论
i just wanted to by flap to replace over batteries it slides on and off reedalice270@gm.com
Alice Reed - 回复
