跳转到主内容
Canon PowerShot A540 LCD Screen Replacement
你所需要的
  1. Canon PowerShot A540 LCD Screen Replacement, Back Cover: 步骤 1 中的图像 1,2 Canon PowerShot A540 LCD Screen Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Turn off the camera.
    • Turn the camera upside-down and press the tab to release the battery cover. Remove the batteries.
  2. Canon PowerShot A540 LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Turn the camera upside down to view the "Card/Batt. Open" Cover.
    • Use a Phillips head #000 screwdriver to remove the three (3) 4.0 mm screws.
  3. Canon PowerShot A540 LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Open "Card/Batt. Open" Cover.
    • Remove the one (1) 5.0 mm screw with the Phillips head #000 screwdriver.
  4. Canon PowerShot A540 LCD Screen Replacement: 步骤 4 中的图像 1,1
    • Turn the camera to the right side of the LCD screen.
    • Remove the three (3) 4.0 mm screws with the Phillips head #000 screwdriver.
  5. Canon PowerShot A540 LCD Screen Replacement: 步骤 5 中的图像 1,3 Canon PowerShot A540 LCD Screen Replacement: 步骤 5 中的图像 2,3 Canon PowerShot A540 LCD Screen Replacement: 步骤 5 中的图像 3,3
    • Gently remove the back cover.
    • Start at the bottom at the corner of the "Card/Batt. Open" Cover.
    • Then move onto the other edges and the top.
    • It may be tight at the top!
  6. Canon PowerShot A540 LCD Screen Replacement, LCD Screen: 步骤 6 中的图像 1,2 Canon PowerShot A540 LCD Screen Replacement, LCD Screen: 步骤 6 中的图像 2,2
    • Turn the camera to view the back.
    • Remove the one (1) 3.0 mm screw on the top right corner of the screen.
    • There is a small metal bar that rests on this frame. Keep it with the screws that have been removed from the camera.
  7. Canon PowerShot A540 LCD Screen Replacement: 步骤 7 中的图像 1,2 Canon PowerShot A540 LCD Screen Replacement: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    • Lift the LCD Screen off of the back to view the attached ribbon cables.
    • Use tweezers to flip the black bar up.
  8. Canon PowerShot A540 LCD Screen Replacement: 步骤 8 中的图像 1,3 Canon PowerShot A540 LCD Screen Replacement: 步骤 8 中的图像 2,3 Canon PowerShot A540 LCD Screen Replacement: 步骤 8 中的图像 3,3
    • Gently pull the big ribbon out.
    • Gently pull the small ribbon out.
    • The small ribbon does not have a bar like the big ribbon.
  9. Canon PowerShot A540 LCD Screen Replacement: 步骤 9 中的图像 1,2 Canon PowerShot A540 LCD Screen Replacement: 步骤 9 中的图像 2,2
    • Use tweezers at the top left of the LCD Screen to wedge the top left of the Outer Frame loose.
    • Use your thumb to hold the Outer Frame open.
    • Use the tweezers at the top right of the LCD Screen to wedge the top right of the Outer Frame loose.
  10. Canon PowerShot A540 LCD Screen Replacement: 步骤 10 中的图像 1,2 Canon PowerShot A540 LCD Screen Replacement: 步骤 10 中的图像 2,2
    • Slide the LCD Screen out from the Outer Frame.
结论
2等其他人完成本指南。
Carley Fuller
于03/23/15注册
434 声望
创作了3篇指南
团队
Baylor, Team 7-12, Williams Spring 2015 Baylor, Team 7-12, Williams Spring 2015 的会员
BU-WILLIAMS-S15S7G12
3 名成员
创作了20篇指南
1指南评论
I wish to purchase a new screen. Where? I feel capable of repair per these instructions and a u tube video.
Geo Schou - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 26
总计 1,245
