跳转到主内容
Canon PowerShot A540 Front Cover Replacement
你所需要的
  1. Canon PowerShot A540 Front Cover Replacement, Back Cover: 步骤 1 中的图像 1,2 Canon PowerShot A540 Front Cover Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Turn off the camera.
    • Turn the camera upside-down and press the tab to release the battery cover. Remove the batteries.
  2. Canon PowerShot A540 Front Cover Replacement: 步骤 2 中的图像 1,1
    • Turn the camera upside down to view the "Card/Batt. Open" Cover.
    • Use a Phillips head #000 screwdriver to remove the three (3) 4.0 mm screws.
  3. Canon PowerShot A540 Front Cover Replacement: 步骤 3 中的图像 1,1
    • Open "Card/Batt. Open" Cover.
    • Remove the one (1) 5.0 mm screw with the Phillips head #000 screwdriver.
  4. Canon PowerShot A540 Front Cover Replacement: 步骤 4 中的图像 1,1
    • Turn the camera to the right side of the LCD screen.
    • Remove the three (3) 4.0 mm screws with the Phillips head #000 screwdriver.
  5. Canon PowerShot A540 Front Cover Replacement: 步骤 5 中的图像 1,3 Canon PowerShot A540 Front Cover Replacement: 步骤 5 中的图像 2,3 Canon PowerShot A540 Front Cover Replacement: 步骤 5 中的图像 3,3
    • Gently remove the back cover.
    • Start at the bottom at the corner of the "Card/Batt. Open" Cover.
    • Then move onto the other edges and the top.
    • It may be tight at the top!
  6. Canon PowerShot A540 Front Cover Replacement, Front Cover: 步骤 6 中的图像 1,2 Canon PowerShot A540 Front Cover Replacement, Front Cover: 步骤 6 中的图像 2,2
    • Turn the camera to view the front.
    • Remove the lens guard.
    • Press the lens guard's button as you turn the guard counterclockwise.
  7. Canon PowerShot A540 Front Cover Replacement: 步骤 7 中的图像 1,1
    • Turn the camera to the side left of the LCD screen.
    • Remove the one (1) 4.0 mm screw with the Phillips head #000 screwdriver.
  8. Canon PowerShot A540 Front Cover Replacement: 步骤 8 中的图像 1,1
    • Remove the front cover gently.
    • When removing the front cover, a thin, black rubber washer may fall off the lens. If it does, make sure to put it back on the lens before reassembly.
结论
2等其他人完成本指南。
Carley Fuller
于03/23/15注册
434 声望
创作了3篇指南
团队
Baylor, Team 7-12, Williams Spring 2015 Baylor, Team 7-12, Williams Spring 2015 的会员
BU-WILLIAMS-S15S7G12
3 名成员
创作了20篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 26
总计 1,450
