跳转到主内容
Canon PowerShot A480 LCD Screen Replacement
你所需要的
  1. Canon PowerShot A480 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 1,3 Canon PowerShot A480 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 2,3 Canon PowerShot A480 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 3,3
    • First, we will start by removing all of the black 5mm screws on the exterior.
    • Flip the camera upside down revealing two black screws on either side of the tripod mount.
    • Turn to the side of the camera closest to the lens to unscrew the third and final black screw.
  2. Canon PowerShot A480 LCD Screen Replacement: 步骤 2 中的图像 1,3 Canon PowerShot A480 LCD Screen Replacement: 步骤 2 中的图像 2,3 Canon PowerShot A480 LCD Screen Replacement: 步骤 2 中的图像 3,3
    • Open the rubber panel on the side of the camera to reveal the last two 5mm exterior screws which are silver.
    • Once you have removed the last of the screws, use an iFixit opening tool to separate the two halves of the camera.
    • Take a half of the camera in each hand and gently pry them apart, pulling up on the side across from where the buttons are located.
  3. Canon PowerShot A480 LCD Screen Replacement: 步骤 3 中的图像 1,3 Canon PowerShot A480 LCD Screen Replacement: 步骤 3 中的图像 2,3 Canon PowerShot A480 LCD Screen Replacement: 步骤 3 中的图像 3,3
    • With the screen now exposed, you must unscrew the three silver 2mm screws attaching it to the body of the camera.
    • Use the iFixit opening tool to lift the screen away from the body so that the only thing connecting it to the rest of the camera is the thin, orange wire cable.
    • Using your pointer finger and thumb, firmly grasp the cable and pull it straight away from the camera to disconnect it.
结论
To reassemble your device, follow these instructions in reverse order using your new LCD display.
4等其他人完成本指南。
Ian Nzabanita
于05/06/19注册
193 声望
撰写一个指南
团队
UW Tacoma, Team S1-G5, Cardinal Spring 2019 UW Tacoma, Team S1-G5, Cardinal Spring 2019 的会员
UWT-CARDINAL-S19S1G5
4 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 12
过去 30 天: 38
总计 1,461
