当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Slide the switch on the battery cover labeled "CARD/BATT. OPEN." to the right.
While still holding the switch, pull the cover down, allowing it to release and open.
Remove the 4mm Phillips #00 screw on the inside of the flap that hides the battery and memory card slots.
Remove the light grey, plastic piece.
Remove the plastic portion of the battery flap cover. The metal piece will remain attached.
Slightly pull on each side of the camera. It should loosen up and come apart.
If it does not pull apart right away, use a little more force.
Do not give up!
Since the tabs have been lifted, the ribbon should now slide out out easily.
Be careful not to distort the ribbon in any way.
Using a spudger, unlock the locking mechanism that holds the lower orange ribbon in place.
Once unlocked, slide out the ribbon.
Using a spudger, unlock the locking mechanism that holds the upper orange ribbon in place.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
