跳转到主内容
Canon PowerShot A460 Front Casing Replacement
你所需要的
  1. Canon PowerShot A460 Front Casing Replacement, Battery: 步骤 1 中的图像 1,1
    • Slide the switch on the battery cover labeled "CARD/BATT. OPEN." to the right.
    • While still holding the switch, pull the cover down, allowing it to release and open.
  2. Canon PowerShot A460 Front Casing Replacement: 步骤 2 中的图像 1,1
    • Tilt the camera slightly to allow the batteries to fall out.
  3. Canon PowerShot A460 Front Casing Replacement: 步骤 3 中的图像 1,1
    • Press on and release the memory card to eject it.
  4. Canon PowerShot A460 Front Casing Replacement, Front Casing: 步骤 4 中的图像 1,1
    • Unscrew the 5mm Phillips #00 screw from the bottom of the camera.
    • Make sure to keep the different size screws organized to make reassembling the camera simpler.
  5. Canon PowerShot A460 Front Casing Replacement: 步骤 5 中的图像 1,1
    • Unscrew the three 2mm Phillips #00 screws that are located on the bottom of the camera.
  6. Canon PowerShot A460 Front Casing Replacement: 步骤 6 中的图像 1,1
    • Remove the 4mm Phillips #00 screw that is located on the left side of the camera, if the display screen is facing you.
  7. Canon PowerShot A460 Front Casing Replacement: 步骤 7 中的图像 1,1
    • Take out the 4mm Phillips #00 screw under the rubber flap on the right end of the camera.
  8. Canon PowerShot A460 Front Casing Replacement: 步骤 8 中的图像 1,2 Canon PowerShot A460 Front Casing Replacement: 步骤 8 中的图像 2,2
    • Remove the second battery cover on the bottom of camera.
    • Take the silver battery out of the camera.
  9. Canon PowerShot A460 Front Casing Replacement: 步骤 9 中的图像 1,3 Canon PowerShot A460 Front Casing Replacement: 步骤 9 中的图像 2,3 Canon PowerShot A460 Front Casing Replacement: 步骤 9 中的图像 3,3
    • Remove the 4mm Phillips #00 screw on the inside of the flap that hides the battery and memory card slots.
    • Remove the light grey, plastic piece.
    • Remove the plastic portion of the battery flap cover. The metal piece will remain attached.
  10. Canon PowerShot A460 Front Casing Replacement: 步骤 10 中的图像 1,3 Canon PowerShot A460 Front Casing Replacement: 步骤 10 中的图像 2,3 Canon PowerShot A460 Front Casing Replacement: 步骤 10 中的图像 3,3
    • Slightly pull on each side of the camera. It should loosen up and come apart.
    • If it does not pull apart right away, use a little more force.
    • Do not give up!
结论
Alex
于01/18/13注册
85 声望
创作了2篇指南
团队
Cal Poly, Team 19-42, Regan Winter 2013 Cal Poly, Team 19-42, Regan Winter 2013 的会员
CPSU-REGAN-W13S19G42
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 782
