跳转到主内容
Canon PowerShot A4000 IS Flash Replacement
你所需要的
  1. Canon PowerShot A4000 IS Flash Replacement, Removing the Screws Anchoring the Front Cover: 步骤 1 中的图像 1,3 Canon PowerShot A4000 IS Flash Replacement, Removing the Screws Anchoring the Front Cover: 步骤 1 中的图像 2,3 Canon PowerShot A4000 IS Flash Replacement, Removing the Screws Anchoring the Front Cover: 步骤 1 中的图像 3,3
    • Remove the battery and data card. Refer to the Battery Removal and Memory Card Removal guides.
    • Use a Philips head screwdriver (PH000) to remove the screws circled in the picture. Screw Sizes: 4 millimeters.
  2. Canon PowerShot A4000 IS Flash Replacement: 步骤 2 中的图像 1,2 Canon PowerShot A4000 IS Flash Replacement: 步骤 2 中的图像 2,2
    • Use the spudger tool to gently lever the front cover off.
  3. Canon PowerShot A4000 IS Flash Replacement, Removing the Flash: 步骤 3 中的图像 1,3 Canon PowerShot A4000 IS Flash Replacement, Removing the Flash: 步骤 3 中的图像 2,3 Canon PowerShot A4000 IS Flash Replacement, Removing the Flash: 步骤 3 中的图像 3,3
    • The flash is not held very securely in the camera so be careful. Make sure someone is holding on to it so it does not fall out.
    • Your flash should come out very easily if you use your spudger to lever it out carefully.
    • Once the bulb piece of the flash is clear of the camera body, simply use your fingers to lift the flash clear of the camera.
结论
Ansley Gardner
于10/13/14注册
761 声望
创作了7篇指南
团队
Clemson, Team 1-3, Benson Fall 2014 Clemson, Team 1-3, Benson Fall 2014 的会员
CLEM-BENSON-F14S1G3
3 名成员
创作了17篇指南
一条评论
Hello! thank you for this flash replacement guide. I would like to know: can the flash be repaired or is it only replaceable? Thank you!
Jeiler AV - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 12
过去 30 天: 33
总计 1,815
