跳转到主内容
Canon PowerShot A4000 IS Camera Lens Error Troubleshooting
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Canon PowerShot A4000 IS Camera Lens Error Troubleshooting, If there is a Visible Gap in the Lens: 步骤 1 中的图像 1,1
    • The first step for a lens error is to gently clean the leans with a clean cloth. If this does not work, then you proceed with the following steps.
    • Apply gentle pressure to the lens cover and move lens in a circular motion until you hear a "click".
  2. Canon PowerShot A4000 IS Camera Lens Error Troubleshooting, If the Menu is Still Accessible: 步骤 2 中的图像 1,1
    • Hold down the menu button for at least 10 seconds and select the "Factory Reset" option to reset your lens.
  3. Canon PowerShot A4000 IS Camera Lens Error Troubleshooting, If the Menu is Not Accessible: 步骤 3 中的图像 1,1
    • Remove the battery from your camera and replace it once it is fully charged or buy a new battery if your current one is over a year old. See Battery Removal for more details.
    • Once the battery is out, remove the memory card from camera as well. See Memory Card Replacement for more details.
    • Turning the camera on without a memory card will reset the camera. If the camera has been reset and displays a memory card error message, then the memory card can be reinserted and the camera turned on once again.
  4. Canon PowerShot A4000 IS Camera Lens Error Troubleshooting, Changing the Battery Does Not Work: 步骤 4 中的图像 1,2 Canon PowerShot A4000 IS Camera Lens Error Troubleshooting, Changing the Battery Does Not Work: 步骤 4 中的图像 2,2
    • Insert the A/V cable then plug the cable into a power supply or computer. Please see Connecting Camera to Computer for further instructions.
    • Turn the camera on by pushing the ON/OFF button.
  5. Canon PowerShot A4000 IS Camera Lens Error Troubleshooting, New Batteries Do Not Work: 步骤 5 中的图像 1,2 Canon PowerShot A4000 IS Camera Lens Error Troubleshooting, New Batteries Do Not Work: 步骤 5 中的图像 2,2
    • While turning the camera on by pushing the ON/OFF button, press and hold the MENU or FUNC. SET button.
终点
Ashley Heslip
于10/13/14注册
309 声望
创作了3篇指南
团队
Clemson, Team 1-3, Benson Fall 2014 Clemson, Team 1-3, Benson Fall 2014 的会员
CLEM-BENSON-F14S1G3
3 名成员
创作了17篇指南
2条评论
My lens is stuck out and won't go back in it says lens error and that it will shut off automatically what do I do?
trudiaguilar - 回复
I have done all of the above recommendations and my camera still has a lens error and lens won’t open… :-(
Rosie Bird - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 3,658
