跳转到主内容
Canon PowerShot A3400 IS Plastic Case Replacement
你所需要的
  1. Canon PowerShot A3400 IS Plastic Case Replacement, Battery: 步骤 1 中的图像 1,1
    • Place thumb on area right next to where it says open and slide to the right to open.
  2. Canon PowerShot A3400 IS Plastic Case Replacement: 步骤 2 中的图像 1,1
    • Remove the battery by pushing the orange object outwards; the battery will spring up and out.
  3. Canon PowerShot A3400 IS Plastic Case Replacement, Plastic Case: 步骤 3 中的图像 1,2 Canon PowerShot A3400 IS Plastic Case Replacement, Plastic Case: 步骤 3 中的图像 2,2
    • Remove the two 5.00 mm screws in the bottom of the casing with a Philips #000 screwdriver
  4. Canon PowerShot A3400 IS Plastic Case Replacement: 步骤 4 中的图像 1,2 Canon PowerShot A3400 IS Plastic Case Replacement: 步骤 4 中的图像 2,2
    • Place the camera on to the side that has the image stabilizer label.
    • Remove the 5.00 mm screws that are on this side using the screwdriver.
  5. Canon PowerShot A3400 IS Plastic Case Replacement: 步骤 5 中的图像 1,1
    • Place camera on to the side with the A/V Out Digital Cover facing up.
    • Remove this visible 5.00 mm screw.
    • Pull the A/V Out Digital cover back to uncover the next step.
  6. Canon PowerShot A3400 IS Plastic Case Replacement: 步骤 6 中的图像 1,1
    • Remove the 5.00 mm screw from behind the cover.
  7. Canon PowerShot A3400 IS Plastic Case Replacement: 步骤 7 中的图像 1,1
    • Make sure the battery cover is open.
  8. Canon PowerShot A3400 IS Plastic Case Replacement: 步骤 8 中的图像 1,2 Canon PowerShot A3400 IS Plastic Case Replacement: 步骤 8 中的图像 2,2
    • Turn the camera onto the side with the A/V out Digital cover.
    • Use your finger to pull this tab to the right.
  9. Canon PowerShot A3400 IS Plastic Case Replacement: 步骤 9 中的图像 1,3 Canon PowerShot A3400 IS Plastic Case Replacement: 步骤 9 中的图像 2,3 Canon PowerShot A3400 IS Plastic Case Replacement: 步骤 9 中的图像 3,3
    • Remove the lens side by using your fingers or a spudger to pry it gently open.
    • Try to pry it loose all around that side so that it is easier to pull off.
  10. Canon PowerShot A3400 IS Plastic Case Replacement: 步骤 10 中的图像 1,3 Canon PowerShot A3400 IS Plastic Case Replacement: 步骤 10 中的图像 2,3 Canon PowerShot A3400 IS Plastic Case Replacement: 步骤 10 中的图像 3,3
    • Using your fingers, pull the screen side gently off.
    • Try to loosen it all around that side so that it is easier to try and pull it off.
结论
另外一个人完成了本指南。
Emily Pretorius
于01/13/15注册
325 声望
创作了3篇指南
团队
USF Tampa, Team 1-1, Sullivan Winter 2015 USF Tampa, Team 1-1, Sullivan Winter 2015 的会员
USFT-SULLIVAN-W15S1G1
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 10
总计 244
