跳转到主内容
Canon PowerShot A2500 Body Casing and Faceplate Replacement
你所需要的
  1. Canon PowerShot A2500 Body Casing and Faceplate Replacement, Body Casing and Faceplate: 步骤 1 中的图像 1,2 Canon PowerShot A2500 Body Casing and Faceplate Replacement, Body Casing and Faceplate: 步骤 1 中的图像 2,2
    • Remove the knot holding the wrist lanyard onto the camera
  2. Canon PowerShot A2500 Body Casing and Faceplate Replacement: 步骤 2 中的图像 1,1
    • Open the latch at the bottom corner of the device to reveal the battery and SD card housing.
    • There is an orange latch holding the battery in place which must be pushed back in order to free the battery.
    • Once the battery is removed push the SD card and this will activate a spring ejecting the card from the camera.
  3. Canon PowerShot A2500 Body Casing and Faceplate Replacement: 步骤 3 中的图像 1,3 Canon PowerShot A2500 Body Casing and Faceplate Replacement: 步骤 3 中的图像 2,3 Canon PowerShot A2500 Body Casing and Faceplate Replacement: 步骤 3 中的图像 3,3
    • Remove the 6 Phillips #00 exterior screws from the camera. Two are located on the bottom and two are located on either side as shown. Notice that one of the screws is under the AV Out Digital flap on the side. All exterior screws should be 2.4mm in length
  4. Canon PowerShot A2500 Body Casing and Faceplate Replacement: 步骤 4 中的图像 1,3 Canon PowerShot A2500 Body Casing and Faceplate Replacement: 步骤 4 中的图像 2,3 Canon PowerShot A2500 Body Casing and Faceplate Replacement: 步骤 4 中的图像 3,3
    • Pry apart the camera casing using the plastic opening tool tool provided. Once the casing has begun to separate pull the two sides apart with your hands.
    • Be careful not to bend the plastic casing to much, as it will crack.
结论
另外一个人完成了本指南。
James Hickey
于03/24/15注册
393 声望
创作了2篇指南
团队
UMass Dartmouth, Team 3-4, Duarte Spring 2015 UMass Dartmouth, Team 3-4, Duarte Spring 2015 的会员
UMASSD-DUARTE-S15S3G4
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 14
总计 459
