跳转到主内容
Canon PowerShot A2300 Front Cover Replacement
你所需要的
  1. Canon PowerShot A2300 Front Cover Replacement, Front Cover: 步骤 1 中的图像 1,1
    • Open the A/V Out Digital port cover on the function button side to reveal a screw.
  2. Canon PowerShot A2300 Front Cover Replacement: 步骤 2 中的图像 1,3 Canon PowerShot A2300 Front Cover Replacement: 步骤 2 中的图像 2,3 Canon PowerShot A2300 Front Cover Replacement: 步骤 2 中的图像 3,3
    • Remove all 6 screws(2.70 mm), 2 on each side and 2 on the bottom.
    • Screws are small and very easily lost.
  3. Canon PowerShot A2300 Front Cover Replacement: 步骤 3 中的图像 1,2 Canon PowerShot A2300 Front Cover Replacement: 步骤 3 中的图像 2,2
    • Open the card/battery latch by sliding the cover away from the camera in the direction indicated by the arrow.
    • Doing this gives a spot to grip on the bottom of the front cover. This will make it easier to handle when removing.
  4. Canon PowerShot A2300 Front Cover Replacement: 步骤 4 中的图像 1,1
    • Gently lift the bottom of the front cover to roughly a 30 degree angle.
  5. Canon PowerShot A2300 Front Cover Replacement: 步骤 5 中的图像 1,1
    • Pull the top of the front cover away from the camera by gripping the top of the front cover by the corners where the cover is still attached to the body.
结论
另外一个人完成了本指南。
Ashley Fincher
于03/23/15注册
477 声望
创作了3篇指南
团队
Baylor, Team 7-14, Williams Spring 2015 Baylor, Team 7-14, Williams Spring 2015 的会员
BU-WILLIAMS-S15S7G14
4 名成员
创作了10篇指南
一条评论
Are the screws really hard to remove, or is it just me?
Alex Hulinsky - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 23
总计 566
