跳转到主内容
Canon PowerShot A2300 Flash Assembly Replacement
你所需要的
  1. Canon PowerShot A2300 Flash Assembly Replacement, Front Cover: 步骤 1 中的图像 1,1
    • Open the A/V Out Digital port cover on the function button side to reveal a screw.
  2. Canon PowerShot A2300 Flash Assembly Replacement: 步骤 2 中的图像 1,3 Canon PowerShot A2300 Flash Assembly Replacement: 步骤 2 中的图像 2,3 Canon PowerShot A2300 Flash Assembly Replacement: 步骤 2 中的图像 3,3
    • Remove all 6 screws(2.70 mm), 2 on each side and 2 on the bottom.
    • Screws are small and very easily lost.
  3. Canon PowerShot A2300 Flash Assembly Replacement: 步骤 3 中的图像 1,2 Canon PowerShot A2300 Flash Assembly Replacement: 步骤 3 中的图像 2,2
    • Open the card/battery latch by sliding the cover away from the camera in the direction indicated by the arrow.
    • Doing this gives a spot to grip on the bottom of the front cover. This will make it easier to handle when removing.
  4. Canon PowerShot A2300 Flash Assembly Replacement: 步骤 4 中的图像 1,1
    • Gently lift the bottom of the front cover to roughly a 30 degree angle.
  5. Canon PowerShot A2300 Flash Assembly Replacement: 步骤 5 中的图像 1,1
    • Pull the top of the front cover away from the camera by gripping the top of the front cover by the corners where the cover is still attached to the body.
  6. Canon PowerShot A2300 Flash Assembly Replacement, Back Cover: 步骤 6 中的图像 1,1
    • Hold the camera in your hands with both thumbs on the screen with the screen faced up.
    • Keep close to the table top in case the camera falls out of your hands.
  7. Canon PowerShot A2300 Flash Assembly Replacement: 步骤 7 中的图像 1,1
    • Pull the the bottom left corner of the cover up about an inch to the point shown in the picture.
    • Do not completely remove the back cover by pulling on the side as shown. The cover is still attached on the top of the camera.
  8. Canon PowerShot A2300 Flash Assembly Replacement: 步骤 8 中的图像 1,1
    • Pry the top off by sliding the spudger under the On/Off button.
  9. Canon PowerShot A2300 Flash Assembly Replacement: 步骤 9 中的图像 1,1
    • Slide the cover to the right and off the camera.
    • Gently pry using the spudger on the right side if necessary.
    • The A/V OUT DIGITAL cover will sometimes become loose and disconnect from the cover
  10. Canon PowerShot A2300 Flash Assembly Replacement, Flash Assembly: 步骤 10 中的图像 1,1
    • Raise the screen by wedging the spudger between the bottom of the screen and the mount hole.
  11. Canon PowerShot A2300 Flash Assembly Replacement: 步骤 11 中的图像 1,1
    • Remove the metal sheet that is under the screen.
  12. Canon PowerShot A2300 Flash Assembly Replacement: 步骤 12 中的图像 1,1
    • Remove the top left screw on the metal sheet that is behind the screen.
    • This screw connects the flash to the metal sheet.
  13. Canon PowerShot A2300 Flash Assembly Replacement: 步骤 13 中的图像 1,1
    • Use one side of the tweezers to raise the orange retaining flap on the zero insertion force (ZIF) connector to a vertical position.
  14. Canon PowerShot A2300 Flash Assembly Replacement: 步骤 14 中的图像 1,1
    • Gently pull the orange ribbon cable out of the ZIF connector using the tweezers.
  15. Canon PowerShot A2300 Flash Assembly Replacement: 步骤 15 中的图像 1,2 Canon PowerShot A2300 Flash Assembly Replacement: 步骤 15 中的图像 2,2
    • Remove the flash by gently rotating slightly back and forth and pulling up.
结论
2等其他人完成本指南。
Nathan McMillan
于03/23/15注册
366 声望
创作了2篇指南
团队
Baylor, Team 7-14, Williams Spring 2015 Baylor, Team 7-14, Williams Spring 2015 的会员
BU-WILLIAMS-S15S7G14
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 19
总计 1,188
