简介
This guide requires you to use a Phillips head screwdriver to remove the screws around the lens.
你所需要的
First, remove the batteries and memory card.
Remove the 5.0 mm black screw with a Phillips #00 screwdriver.
Remove the 5.0 mm silver screw with a Phillips #00 screwdriver.
Begin taking off the back cover with a plastic opening tool.
Begin by wedging the plastic opening tool behind the bottom left corner of the LCD screen as shown.
Slide the plastic opening tool to the right, along the mating edge, to pry off the back cover.
Continue taking off the back cover along the left side of the camera as seen in the third picture.
Lift up the electrical ribbon shown to access the next screw.
Remove the 3.9 mm screw with a Phillips #00 screwdriver.
Locate ribbon flap, enclosed in red. (picture 1)
Using a plastic opening tool, lift up the ribbon flap to allow insertion of the LCD ribbon. (picture 2)
Place the LCD screen on the camera and align the ribbon underneath the open ribbon flap. Close the ribbon flap onto the ribbon. (picture 3)
Remove the two 5.3 mm screws circled in red with a Phillips #00 screwdriver.
Remove the 4.4 mm screw circled in orange with a Phillips #00 screwdriver.
另外一个人完成了本指南。
3条评论
Great guide, used it to tear down my A2200. Found an internal battery:MS6145E located on the top ICB (where the flash is,) does anyone know what this does/powers?
My camera, according to Canon USA has a bad sensor(?) because the display fails after taking one photo, but they did not say what sensor or its location. I tore it down looking for sensors and found one for the flash/redeye and a questionable object (I don’t think it’s a sensor.)
If the issue persists, you need to go ahead and update your printer driver. Go to the website of the manufacturer and search for your Canon Printer Error State drivers. Download the driver's recent version manually.
Smith John - 回复
Thanks to your brilliant guide I can remove the lens of my A2200 camera and am in a position to insert a replacement. Please where do I get one from?
