跳转到主内容
Canon PowerShot A2200 Front Cover Replacement
你所需要的
  1. Canon PowerShot A2200 Front Cover Replacement, Back Cover: 步骤 1 中的图像 1,1
    • First, remove the batteries and memory card.
    • Remove the 5.0 mm black screw with a Phillips #00 screwdriver.
    • Remove the 5.0 mm silver screw with a Phillips #00 screwdriver.
  2. Canon PowerShot A2200 Front Cover Replacement: 步骤 2 中的图像 1,1
    • Remove the 5.0 mm black screw on the right with a Phillips #00 screwdriver.
  3. Canon PowerShot A2200 Front Cover Replacement: 步骤 3 中的图像 1,1
    • Remove the 5.0 mm screw on the left with a Phillips #00 screwdriver.
  4. Canon PowerShot A2200 Front Cover Replacement: 步骤 4 中的图像 1,3 Canon PowerShot A2200 Front Cover Replacement: 步骤 4 中的图像 2,3 Canon PowerShot A2200 Front Cover Replacement: 步骤 4 中的图像 3,3
    • Begin taking off the back cover with a plastic opening tool.
    • Begin by wedging the plastic opening tool behind the bottom left corner of the LCD screen as shown.
    • Slide the plastic opening tool to the right, along the mating edge, to pry off the back cover.
    • Continue taking off the back cover along the left side of the camera as seen in the third picture.
  5. Canon PowerShot A2200 Front Cover Replacement: 步骤 5 中的图像 1,3 Canon PowerShot A2200 Front Cover Replacement: 步骤 5 中的图像 2,3 Canon PowerShot A2200 Front Cover Replacement: 步骤 5 中的图像 3,3
    • Use the plastic opening tool to separate the top section of the back cover from the frame.
    • Once there is enough separation between the back cover and the frame, remove the back cover for replacement.
  6. Canon PowerShot A2200 Front Cover Replacement, Button Assembly: 步骤 6 中的图像 1,2 Canon PowerShot A2200 Front Cover Replacement, Button Assembly: 步骤 6 中的图像 2,2
    • Remove the internal 4.4mm screw with a Phillips 00 screwdriver.
    • Make sure you're removing the screw circled in red, not the screw crossed out in orange.
  7. Canon PowerShot A2200 Front Cover Replacement: 步骤 7 中的图像 1,1
    • Gently lift of the buttons for replacement. They should come off without excessive force.
    • If the buttons do not lift off easily, you may have unscrewed the wrong screw. Revert to previous step.
  8. Canon PowerShot A2200 Front Cover Replacement, LCD Screen: 步骤 8 中的图像 1,1
    • Lift up the electrical ribbon shown to access the next screw.
    • Remove the 3.9 mm screw with a Phillips #00 screwdriver.
  9. Canon PowerShot A2200 Front Cover Replacement: 步骤 9 中的图像 1,1
  10. Canon PowerShot A2200 Front Cover Replacement: 步骤 10 中的图像 1,1
    • Remove the two 3.9 mm screws shown with a Phillips #00 screwdriver.
  11. Canon PowerShot A2200 Front Cover Replacement: 步骤 11 中的图像 1,2 Canon PowerShot A2200 Front Cover Replacement: 步骤 11 中的图像 2,2
    • There is an electrical flap that holds the LCD ribbon down. Note the flap in is closed position.
    • Lift up the flap with a plastic opening tool.
  12. Canon PowerShot A2200 Front Cover Replacement: 步骤 12 中的图像 1,1
    • Holding the outer frame of the LCD screen, gently lift the LCD screen for replacement.
  13. Canon PowerShot A2200 Front Cover Replacement: 步骤 13 中的图像 1,3 Canon PowerShot A2200 Front Cover Replacement: 步骤 13 中的图像 2,3 Canon PowerShot A2200 Front Cover Replacement: 步骤 13 中的图像 3,3
    • This step is only for replacement. If you are not replacing the LCD screen, skip this step.
    • Locate ribbon flap, enclosed in red. (picture 1)
    • Using a plastic opening tool, lift up the ribbon flap to allow insertion of the LCD ribbon. (picture 2)
    • Place the LCD screen on the camera and align the ribbon underneath the open ribbon flap. Close the ribbon flap onto the ribbon. (picture 3)
  14. Canon PowerShot A2200 Front Cover Replacement, Lens Assembly: 步骤 14 中的图像 1,1
    • Remove the two 5.3 mm screws circled in red with a Phillips #00 screwdriver.
    • Remove the 4.4 mm screw circled in orange with a Phillips #00 screwdriver.
  15. Canon PowerShot A2200 Front Cover Replacement: 步骤 15 中的图像 1,2 Canon PowerShot A2200 Front Cover Replacement: 步骤 15 中的图像 2,2
    • Gently press the front of the lens to begin to remove it from the frame.
    • Gently angle out the lens from the frame as seen in picture 2.
    • A thin circular ribbon should fall out from the front of the lens. Note its original location on the front cover for reassembly.
  16. Canon PowerShot A2200 Front Cover Replacement: 步骤 16 中的图像 1,3 Canon PowerShot A2200 Front Cover Replacement: 步骤 16 中的图像 2,3 Canon PowerShot A2200 Front Cover Replacement: 步骤 16 中的图像 3,3
    • Locate the two electrical ribbons that are attached to the main motherboard.
    • Lift up the two black flaps on the motherboard that hold the electrical ribbons in place.
    • Gently remove the lens for replacement.
  17. Canon PowerShot A2200 Front Cover Replacement, Front Cover: 步骤 17 中的图像 1,1
    • Remove the two 4.4 mm screws shown with a Phillips #00 screwdriver.
  18. Canon PowerShot A2200 Front Cover Replacement: 步骤 18 中的图像 1,1
    • Remove the 4.4 mm screw shown with a Phillips #00 screwdriver.
  19. Canon PowerShot A2200 Front Cover Replacement: 步骤 19 中的图像 1,1
    • Gently remove the front cover for replacement.
结论
另外一个人完成了本指南。
Benjamin Gee
于03/31/15注册
929 声望
创作了5篇指南
团队
Baylor, Team 4-5, Williams Spring 2015 Baylor, Team 4-5, Williams Spring 2015 的会员
BU-WILLIAMS-S15S4G5
4 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 27
总计 1,021
