跳转到主内容
Canon PowerShot A2200 Button Assembly Replacement
你所需要的
  1. Canon PowerShot A2200 Button Assembly Replacement, Back Cover: 步骤 1 中的图像 1,1
    • First, remove the batteries and memory card.
    • Remove the 5.0 mm black screw with a Phillips #00 screwdriver.
    • Remove the 5.0 mm silver screw with a Phillips #00 screwdriver.
  2. Canon PowerShot A2200 Button Assembly Replacement: 步骤 2 中的图像 1,1
    • Remove the 5.0 mm black screw on the right with a Phillips #00 screwdriver.
  3. Canon PowerShot A2200 Button Assembly Replacement: 步骤 3 中的图像 1,1
    • Remove the 5.0 mm screw on the left with a Phillips #00 screwdriver.
  4. Canon PowerShot A2200 Button Assembly Replacement: 步骤 4 中的图像 1,3 Canon PowerShot A2200 Button Assembly Replacement: 步骤 4 中的图像 2,3 Canon PowerShot A2200 Button Assembly Replacement: 步骤 4 中的图像 3,3
    • Begin taking off the back cover with a plastic opening tool.
    • Begin by wedging the plastic opening tool behind the bottom left corner of the LCD screen as shown.
    • Slide the plastic opening tool to the right, along the mating edge, to pry off the back cover.
    • Continue taking off the back cover along the left side of the camera as seen in the third picture.
  5. Canon PowerShot A2200 Button Assembly Replacement: 步骤 5 中的图像 1,3 Canon PowerShot A2200 Button Assembly Replacement: 步骤 5 中的图像 2,3 Canon PowerShot A2200 Button Assembly Replacement: 步骤 5 中的图像 3,3
    • Use the plastic opening tool to separate the top section of the back cover from the frame.
    • Once there is enough separation between the back cover and the frame, remove the back cover for replacement.
  6. Canon PowerShot A2200 Button Assembly Replacement, Button Assembly: 步骤 6 中的图像 1,2 Canon PowerShot A2200 Button Assembly Replacement, Button Assembly: 步骤 6 中的图像 2,2
    • Remove the internal 4.4mm screw with a Phillips 00 screwdriver.
    • Make sure you're removing the screw circled in red, not the screw crossed out in orange.
  7. Canon PowerShot A2200 Button Assembly Replacement: 步骤 7 中的图像 1,1
    • Gently lift of the buttons for replacement. They should come off without excessive force.
    • If the buttons do not lift off easily, you may have unscrewed the wrong screw. Revert to previous step.
结论
另外一个人完成了本指南。
Benjamin Gee
于03/31/15注册
983 声望
创作了5篇指南
团队
Baylor, Team 4-5, Williams Spring 2015 Baylor, Team 4-5, Williams Spring 2015 的会员
BU-WILLIAMS-S15S4G5
4 名成员
创作了13篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 869
