跳转到主内容
Canon PowerShot A2200 Back Cover Replacement
你所需要的
  1. Canon PowerShot A2200 Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,1
    • First, remove the batteries and memory card.
    • Remove the 5.0 mm black screw with a Phillips #00 screwdriver.
    • Remove the 5.0 mm silver screw with a Phillips #00 screwdriver.
  2. Canon PowerShot A2200 Back Cover Replacement: 步骤 2 中的图像 1,1
    • Remove the 5.0 mm black screw on the right with a Phillips #00 screwdriver.
  3. Canon PowerShot A2200 Back Cover Replacement: 步骤 3 中的图像 1,1
    • Remove the 5.0 mm screw on the left with a Phillips #00 screwdriver.
  4. Canon PowerShot A2200 Back Cover Replacement: 步骤 4 中的图像 1,3 Canon PowerShot A2200 Back Cover Replacement: 步骤 4 中的图像 2,3 Canon PowerShot A2200 Back Cover Replacement: 步骤 4 中的图像 3,3
    • Begin taking off the back cover with a plastic opening tool.
    • Begin by wedging the plastic opening tool behind the bottom left corner of the LCD screen as shown.
    • Slide the plastic opening tool to the right, along the mating edge, to pry off the back cover.
    • Continue taking off the back cover along the left side of the camera as seen in the third picture.
  5. Canon PowerShot A2200 Back Cover Replacement: 步骤 5 中的图像 1,3 Canon PowerShot A2200 Back Cover Replacement: 步骤 5 中的图像 2,3 Canon PowerShot A2200 Back Cover Replacement: 步骤 5 中的图像 3,3
    • Use the plastic opening tool to separate the top section of the back cover from the frame.
    • Once there is enough separation between the back cover and the frame, remove the back cover for replacement.
结论
团队
Baylor, Team 4-5, Williams Spring 2015 Baylor, Team 4-5, Williams Spring 2015 的会员
BU-WILLIAMS-S15S4G5
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 24
总计 1,003
