1. Start by removing the case in the previous guide. The battery door is held in place with a steel dowel but first undo the spring tension by lifting the spring out of it's retainer with a pair of tweezers or small screwdriver. The battery door is held in place with a steel dowel but first undo the spring tension by lifting the spring out of it's retainer with a pair of tweezers or small screwdriver.
    • Start by removing the case in the previous guide.
    • The battery door is held in place with a steel dowel but first undo the spring tension by lifting the spring out of it's retainer with a pair of tweezers or small screwdriver.
  2. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
    善于维修,即天赋异禀。
    与 #ImAGenius 分享您的维修故事
    我们都是天才
  3. Once the spring is clear of the plastic, you can easily push the dowel through with a pin, the end of the tweezers, or a paperclip. Grab the dowel from the other end and pull it out. Grab the dowel from the other end and pull it out.
    • Once the spring is clear of the plastic, you can easily push the dowel through with a pin, the end of the tweezers, or a paperclip.
    • Grab the dowel from the other end and pull it out.
结论
4等其他人完成本指南。
Biff Wheeler
于2012年06月06日注册
762 信誉积分
创作了4篇指南
Hi I have the camera of same model A1000.
Where can I get the battery cover, mine is broken?
Please share the details.
Chennakeshava Reddy Palla - 回复
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 24
总计 2,583
