当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Remove the two 7.9 mm screws using a Phillips #1 screwdriver.
Lift up the back cover to remove it.
You may need to lift firmly as it requires quite a bit of force.
Open the front tray.
Open the scanner compartment.
Make sure the blue lever locks into place to keep the compartment open.
Remove the blue lever from its slot by pushing it back and twisting clockwise.
Close the scanner compartment and cover.
Pry open the side cover with the plastic opening tool.
Flip the printer over so that the bottom of the printer is facing you.
Use the plastic opening tool to remove the corner of the side panel from the plastic pin.
Use the plastic opening tool to loosen the side panel from the bottom of the printer.
Using the plastic opening tool, pry off the top cover of the LCD assembly.
Pry around the front and side edges for the easiest removal.
After removing the top cover of the LCD assembly, remove the LCD using the plastic opening tool.
Gently pull the ribbon cable to remove the LCD completely.
Locate the buttons on the top of the printer.
Using the plastic opening tool, gently pry under the button cover to remove it from its fixture.
Remove the five 7.7 mm screws using a Phillips #1 screwdriver.
Using the plastic opening tool, gently pry around the cover behind the LCD screen to remove it from its fixture.
Remove the two 7.8 mm screws using a Phillips #1 screwdriver.
Gently pull the LCD screen up to remove it from its fixture.
Use the plastic opening tool to pry off the plastic button assembly.
Gently pull the plastic button assembly up to remove it.
The plastic button assembly has a ribbon cable connected on the bottom, so be careful pulling it.
Remove the ribbon cable connected to the backside of the plastic button assembly.
Remove the seven 8.7 mm screws using the Phillips #1 screwdriver.
Locate the spring that holds the PCB in place on the bottom left of the plastic button assembly.
Gently lift the spring and pull the board out of its plastic button assembly.
Remove the buttons from the plastic button assembly.
取消:我没有完成这个指南。
与8其他贡献者
于01/14/13注册
114 声望
创作了2篇指南
徽章: 7
+ 4更多徽章
CPSU-REGAN-W13S19G41
4 名成员
创作了6篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 1,684
