当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Press the power button to turn on the printer.
Pull down the front output tray cover.
Lift the printer lid.
Allow the belt, containing ink cartridges, to adjust and center so that the ink cartridges are visible.
Push in the white clip to release the ink cartridge from the printhead.
Lift the ink cartridge from the printhead.
Repeat this process for the remaining ink cartridges.
You have successfully removed all ink cartridges.
After removing all ink cartridges, lift the printhead lock lever.
Pull up and lift out the black piece that previously held the ink cartridges. This is the printhead.
You have successfully removed your printhead.
取消:我没有完成这个指南。
5等其他人完成本指南。
与2其他贡献者
于10/07/14注册
1,184 声望
创作了4篇指南
徽章: 16
+ 13更多徽章
USFT-LEAHY-F14S1G3
3 名成员
创作了8篇指南
fairly helpful, especially the photo's. but I need advice on how to clean the printhead before trying to replace it,
a1halber - 2016年9月6日 回复
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 39
总计 7,666
