跳转到主内容
修复你的物品
维修的权力
商店
简介
If your printed documents or images are becoming distorted due to a dysfunctional printhead, use this guide to replace the printhead.
  1. Press the power button to turn on the printer.
    • Press the power button to turn on the printer.
  2. Pull down the front output tray cover.
    • Pull down the front output tray cover.
  3. Lift the printer lid.
    • Lift the printer lid.
  4. Allow the belt, containing ink cartridges, to adjust and center so that the ink cartridges are visible.
    • Allow the belt, containing ink cartridges, to adjust and center so that the ink cartridges are visible.
  5. Push in the white clip to release the ink cartridge from the printhead. Lift the ink cartridge from the printhead.
    • Push in the white clip to release the ink cartridge from the printhead.
    • Lift the ink cartridge from the printhead.
    • Repeat this process for the remaining ink cartridges.
    • You have successfully removed all ink cartridges.
  6. After removing all ink cartridges, lift the printhead lock lever.
    • After removing all ink cartridges, lift the printhead lock lever.
  7. Pull up and lift out the black piece that previously held the ink cartridges. This is the printhead.
    • Pull up and lift out the black piece that previously held the ink cartridges. This is the printhead.
  8. You have successfully removed your printhead.
    • You have successfully removed your printhead.
结论
3等其他人完成本指南。
Caitlyn
于2014年10月07日注册
1,019 信誉积分
创作了4篇指南
团队
USF Tampa, Team 1-3, Leahy Fall 2014 USF Tampa, Team 1-3, Leahy Fall 2014 的会员
USFT-LEAHY-F14S1G3
3 名成员
创作了4篇指南
fairly helpful, especially the photo's. but I need advice on how to clean the printhead before trying to replace it,
a1halber - 回复
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 12
过去的30天: 63
总计 5,678
